04-14-2017, 08:44 PM | #1 |
Headlamp ring
I replaced the bulb on my '87 c20 that has single headlamps (I have two headlamps total, each with an integral hi/low beam).
Unfortunately I broke the tabs on the headlamp retaining ring. I see Dorman offers a replacement kit http://www.dormanproducts.com/p-7574...Kit&origin=YMM I dont want the whole kit for $50 https://www.amazon.com/Dorman-42437-...s=dorman+42437, I just want the ring for my 6054 bulb. I see there are rings for the same bulb, on jeeps https://www.amazon.com/Dorman-42430-...s=Dorman+42430 and fords http://www.ebay.com/itm/Headlight-Re...3D172153263670 and chevy s10's http://www.ebay.com/itm/Chevy-S10-He...RWwdrY&vxp=mtr Will any of these other rings that fit 6054 bulbs fit my c20? Is GM p/n 5969466 the correct part number for the ring? |
04-16-2017, 10:13 AM | #2 |
Re: Headlamp ring
anyone?
04-16-2017, 10:35 AM | #3 |
Re: Headlamp ring
Common for the tabs to break when removing the ring after all these years. I would try to find one at a recycle yard near you. The Jeep ring may work but not sure if the tabs are in the same place as your original.
04-17-2017, 09:24 AM | #4 |
Re: Headlamp ring
Most of these trucks are gone by me, rusted and crushed years ago. Only the more valuable late model cars remain.
Anyone else know the answer? |
04-17-2017, 05:03 PM | #5 |
Dino burner
Re: Headlamp ring
You can use a Dorman 42407, which retails for about $10. It has more than one set of mounting holes in the tabs, so it fits many different GM, Ford, Dodge, Jeep, etc models that use the 6052/H6054 sealed beams.
04-17-2017, 06:53 PM | #6 |
Re: Headlamp ring
I knew someone had the answer.
Thank you! |
04-24-2017, 11:16 AM | #7 |
Re: Headlamp ring
I got the Dorman 42407 from Amazon and it fit great.
No more "headlight droop" on one side! |
04-25-2017, 10:27 PM | #8 |
Dino burner
Re: Headlamp ring
04-24-2017, 07:50 PM | #9 |
Re: Headlamp ring
I just welded mine back on
Chris _______________________________ 1979 Chevy Stepside SPORT 2018 Chevy Silverado, 39 years apart My build 2008-2016. http://m.imgur.com/a/bURrE |
Tags |
6054 headlamp ring |
