Old 04-16-2017, 07:24 PM   #1
terry b
terry b's Avatar
Dash cluster.
Restored my dash cluster. Painted needle's. Polished the lens. Question about which gage bulb to hook the wire that powers the shift indicator. Also trailer wire plug. Ever seen one like it?
terry b is offline   Reply With Quote
Old 04-16-2017, 09:46 PM   #2
72 tigger
72 tigger's Avatar
Re: Dash cluster.
Looks really nice! Plug looks like a regular taillight harness plug to me
72 tigger is offline   Reply With Quote
Old 04-16-2017, 10:12 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Re: Dash cluster.
If you have a tilt column it will have a single Grey wire that comes down out of the column housing and connects to a spade terminal by the "CLSTR FEED" fuse in the fuse panel. If you have a non-tilt column you will have a Fiber Optic cable, not a wire and there is a special bulb holder that fits into the location that your pen is pointing to that holds the Fiber Optic cable on that end.
LockDoc
Leon
Old 04-17-2017, 08:21 PM   #4
towbar
towbar's Avatar
Location: Marshall, NC....heart of the Appalachians.....aka, Gods country!!
Re: Dash cluster.
A big ol "Thank You" LockDoc!!
towbar is offline   Reply With Quote
Old 04-17-2017, 10:34 PM   #5
LockDoc
LockDoc's Avatar
Re: Dash cluster.
No problem, glad I could help....
LockDoc
Leon
Old 04-16-2017, 10:11 PM   #6
towbar
towbar's Avatar
Re: Dash cluster.
sub'd
Got the same question about where the shift indicator light powers up from??
Old 04-16-2017, 10:30 PM   #7
El Dorado Jim
Re: Dash cluster.
looks like the plug that connects underneath the back of the truck on the frame,connects the front wire harness to the back harness...
El Dorado Jim is offline   Reply With Quote
Old 04-17-2017, 03:43 PM   #8
terry b
terry b's Avatar
Re: Dash cluster.
The plug was at the rear most cross member to plug the taillights in. Thanks for the help
Old 04-18-2017, 01:07 AM   #9
In The Ten Ring
Re: Dash cluster.
terry b,
Could you post the steps you went through on your cluster rehab?
In The Ten Ring is offline   Reply With Quote
