Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 04-17-2017, 04:35 PM   #1
Super73
Super73's Avatar
Temporary Power Plant
With my motor being down and having a tremendous amount of things going on, I wont be getting the pleasure of running my truck for a while.
However, my buddy has a 56 Chevy truck that was a single turbo LS and it is in need of a cage and rear chassis work. We have come together and are putting his now twin 69mm turbo power plant in my truck. He will be leaving his 56 with me to have a local chassis shop back half and cage it, similar to my set up.
We had to redo a few things in my chassis like cut the motor plate free and lower it so the back of the intake would clear the fire wall. Had to move the alternator bracket which was on the frame. Some minor stuff that just eats time.
But we should have it up and running for a dyno session on Thursday, then to the track on Saturday so he can make license passes.
He has a couple sponsorships and my truck will be at the Vegas LS fest in one of his sponsors booths and running the new truck class.
It will be interesting to say the least.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 04-17-2017, 04:49 PM   #2
tinydb84
tinydb84's Avatar
Re: Temporary Power Plant
I've been following the feud on Instagram (not sure if it is real or not). Can you give us some specs on that motor?
David
Instagram: myfabguy
Old 04-17-2017, 09:27 PM   #3
Super73
Super73's Avatar
Tiny,
It's not general knowledge yet that we are doing this together. My guess is there will be more announced by my buddy in the near future.
It is his 370" LS shortblock wearing my heads that flow 365cfm and by my standard a small cam. Turbos are 69mm with truck manifolds. It should make decent power.
Old 04-18-2017, 12:13 PM   #4
hotrod 80
mini truck racer
hotrod 80's Avatar
Hell yeah!
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 04-18-2017, 12:24 PM   #5
tinydb84
tinydb84's Avatar
Very cool. Can't wait to see how fast you go.
David
Instagram: myfabguy
Old 04-18-2017, 10:08 PM   #6
Marv D
Registered Truck Offender
Marv D's Avatar
OMG,, every time I blink Shaun you get a little more CRAZY.
Wait, no I mean this truck gets a little more crazy (but someone had to set the example LOL)
So tomorrow is dyno day?
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 04-20-2017, 08:11 PM   #7
Super73
Super73's Avatar
Had a few Hick ups, dyno tomorrow, track on Sat.
Old 04-23-2017, 09:29 AM   #8
Marv D
Marv D's Avatar
Did ya make it to either???
Old 04-23-2017, 01:05 PM   #9
Super73
Super73's Avatar
Made it on the dyno.
We hadnt even fired it due to a fuel line leak. We had to make a couple new lines and the steel braided i had laying around puked fuel badly. The local fitting/line supplier met me at the dyno and we fixed that.
Then we fought a map wiring issue. We had to wire in a 3bar map and the diagram I had was confusing. Connector had letters while diagram had numbers. We sorted this out.
Fought boost controller / waste gate springs. 8lb spring first pull it went to 280kpa (27ish lbs) real fast and we lifted. Turned the controller off, same thing. Moved some vacuum lines around and it got better but we still saw 15lbs with no controller riding the springs.
Then we fought fuel. For some reason my Weldon 2035 was not keeping up. Found it was only seeing 9 volts.... jumped it direct to a battery but still loosing pressure. Thinking it needs a better alternator and perhaps a boost a pump.
It made 78X Rwhp at 6,100 going lean. It should spin 7,200 all day long. So there is still a lot of power to be had.
Old 04-23-2017, 09:18 PM   #10
Marv D
Marv D's Avatar
Holy crap. 780 Rwhp and an easy 1000+RPM to go,, that's making some nice steam.
Keep us up to date once you get the problems sorted out.
Old 04-24-2017, 12:57 AM   #11
Super73
Super73's Avatar
What is interesting is getting it from 9v to 12v on the fuel pump, no changes to the tune, it picked up 70ish rwhp. That was at 6100 rpm and 14afr.. should be 11.3 to 11.7... I figure fuel alone will make more power.
Old 05-03-2017, 06:27 PM   #12
Super73
Super73's Avatar
Fuel pump got rewired directly to the battery through a fuse and relay.
Alternator got swapped to a higher amp variant.
Truck got on the dyno (not sure why limiter was not bumped up, I was not there) but it made good numbers at 15lbs and only 6,500rpm. I am not at liberty to say what it made but it will likely run as fast or faster than I have gone.
Truck went to Irwindale and on 8lbs ran:
1.67 rolling in to throttle (data logger shows it wasn't even fully on the verter until 1.3 seconds in to the pass)
4.3x at the 330"
6.6x at 85mph (lifted at 5.1 seconds in the data logger)
For reference I looked at one of my 9.4x passes:
1.41 60'
3.96 at the 330'
5.9x @ 116mph
I would have to say, most of the difference is in the 60' and this combo makes boost on the 2-step/tbrake. So I don't think that will be an issue I honestly think at 8-9lbs it will comfortably go 9.4x. My buddy Griffin will be running it at LSFest in the new truck class.
Old 05-06-2017, 01:45 AM   #13
Super73
Super73's Avatar
8lbs of boost with 2step set at 4,000rpm (2lbs at the line). This in Vegas so elevation and hot. Should be interesting at 15lbs, sea-level and 70* temps..
Old 05-06-2017, 09:57 PM   #14
Super73
Super73's Avatar
Still on 8lbs..
1.38 60'
9.24 at 147.9mph
Old 05-07-2017, 07:30 PM   #15
PGSigns
PGSigns's Avatar
Looks like you are getting a handle on it. What happened on the RT on that pass?
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 05-08-2017, 11:52 AM   #16
Super73
Super73's Avatar
RT was simply a function of it being test and tune session, Griffin getting used to the program in the truck and making his license passes.
Old 05-16-2017, 08:36 AM   #17
Marv D
Marv D's Avatar
Shauns truck getting a little internet press
Old 05-22-2017, 11:48 PM   #18
71Dragtruck
71Dragtruck's Avatar
Video showed up on my YouTube recommended list.
https://m.youtube.com/watch?v=SfMMGx8ASKE
Speed is just a matter of money, question is how fast can you afford to go?
8.95@148.97mph all motor haven't tried bottle yet
Sponsored by:
Getz Oilfield Consulting
Hard Candy Customs
71Dragtruck is offline   Reply With Quote
Old 05-23-2017, 08:52 AM   #19
hotrod 80
mini truck racer
hotrod 80's Avatar
Ba
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
