Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 04-17-2017, 09:03 PM   #1
65chevysub
65chevysub's Avatar
License plate mounting
I picked up a rusty tailgate for parts yesterday from Billy(66burban) and in trying to get the license plate bracket off, I noticed it is held on with clutch head bolts. Who sells a bit to remove them?
65chevysub is offline   Reply With Quote
Old 04-17-2017, 10:15 PM   #2
66 Burban
66 Burban's Avatar
Re: License plate mounting
Paul,
Try Harbor Freight, Tractor Supply, Ace and auto parts stores...
Remember: "When seconds count, the Police are only minutes away".
Thx,
Billy B.
66 Burban is offline   Reply With Quote
Old 04-17-2017, 10:24 PM   #3
65chevysub
65chevysub's Avatar
Thanks. The panel is small enough so I can take it with me. Just have to watch the sharp edges
Old 04-18-2017, 12:50 AM   #4
Captainfab
60-66 Nut
You might find a clutch head screwdriver at Napa but not at HF, Tractor Supply or Ace Hardware. You might even have to purchase online.
Old 04-18-2017, 09:38 AM   #5
1966burb
1966burb's Avatar
Lots of them available on eBay. J
1966burb is offline   Reply With Quote
Old 04-18-2017, 09:52 AM   #6
bpmcgee
bpmcgee's Avatar
http://www.classicindustries.com/pro...ts/cx1531.html
If I recall, I think my local Ace actually had one too.
I have a question for you, 65. My 'burb has the bracket for the top of the plate, and 2 holes in the gate for the bottom of the bracket, but I don't think there are captive bolts in those bottom holes -- how does the bottom of the plate fasten down?
B
bpmcgee is offline   Reply With Quote
Old 04-18-2017, 04:47 PM   #7
65chevysub
65chevysub's Avatar
it doesn't. It just "hangs" there and vibrates around. My dad drilled two holes that match the license plate through the lower door, and ran 2 carriage bolts from the inside out, and put star washers and acorn nuts on it and the license plate frame. when I get home, I will take a picture of it to show you what it looks like. This way the plate doesn't drop when I lower the tailgate.
Old 04-18-2017, 05:42 PM   #8
65chevysub
65chevysub's Avatar
B
My mistake. I started with carriage bolts but went to standard bolts so I can put a wrench on it. Hope this helps
Old 04-18-2017, 06:35 PM   #9
Llay R. Rac
Llay R. Rac's Avatar
i used 2 nylon headlight adjustment nuts, with a large headed phillips thru the plate. years later when the nylon dried out and cracked i replaced them with plastic drywall anchors and the same screws.
1965 Suburban, 2 wd.,292, 4-speed.
proudly owned and operated since Valentines day 1969.
Llay R. Rac is offline   Reply With Quote
Old 04-19-2017, 09:26 AM   #10
bpmcgee
bpmcgee's Avatar
Drywall anchors is a very clever idea!
B
Old 04-19-2017, 01:40 PM   #11
65chevysub
65chevysub's Avatar
B
I never thought of those
Old 04-19-2017, 09:34 PM   #12
Llay R. Rac
I also use drywall anchors to secure my door scuff plates because a few of the holes are enlarged due to rust.
