Old 10-20-2003, 08:08 AM   #1
hexafamily
V8 Information
I am rebuilding a '72 for my son. I am trying find out what V8 I have in the truck. The engine came partially disassembled and the guy I bought the truck from couldn't tell a straight story if he had to. The engine appears to be a collection of different parts ( possibly a remanufactured engine). The date codes if I read right are '69 block and '78 heads. The part numbers (if I read right) are heads 333882, and block 14016379. Can anyone idenify if these are the correct years or if not , what years they are. Any help would be appreciated.
Don
hexafamily is offline   Reply With Quote
Old 10-20-2003, 08:28 AM   #2
BadAssChevy502
Yeh It's Fast
BadAssChevy502's Avatar
Thumbs up This is what i have found on these numbers
Block number: 14016379...350...77-79...2 or 4
Head number: 333882.....74-80...350/400......76cc chambers
Hope this helpes you further
(I'm sorry if the spelling isn't correct,i'm trying the best I can )
1972 C20 3/4 Pickup Fleetside 502ci Th400
Click here to view pictures of my truck
1971 C20 3/4 Pickup Fleetside 350ci 3speed manual gearbox
"IF IT AIN'T BROKE DON'T TRY TO FIX IT"
Zwijndrecht,
The Netherlands
Europe
BadAssChevy502 is offline   Reply With Quote
Old 10-20-2003, 09:50 AM   #3
nightmare
nightmare's Avatar
if there is a stock carb that came with it, what are the numbers on there? by the way, depending on what GM codes are on the heads, those are some of the better stock heads.
Mike
2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip
1972 Chevy Suburban - Turquoise/Black
1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD
Using your turn signal is not "giving information to the enemy"
67-72 FAQ
Originally Posted by GMCMAX View Post
My lugnuts require more torque than your honda makes!
nightmare is offline   Reply With Quote
Old 10-20-2003, 11:32 AM   #4
hexafamily
Thanks guys. Make sense. Its a two bolt main block and unfortunatly there is no carb. The guy did say it ran real well. We'll see when I get it rebuilt. Now I know what I'm looking at.
Don
Old 10-20-2003, 11:42 AM   #5
CPNE
Resident Curmudgeon
CPNE's Avatar
Not sure if you've been given this URL but you canclick here for a site that has casting # info.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 10-21-2003, 02:16 AM   #6
BadAssChevy502
Yeh It's Fast
Thumbs up this is the same site i used
this is where i got the info from ,good luck on the project
Zwijndrecht,
The Netherlands
Europe
Old 10-21-2003, 02:47 AM   #7
Randy70C-10
Randy70C-10's Avatar
Those heads should flow decent but they are prone to cracking because of the thin casting, so be careful.
Randy70C-10 is offline   Reply With Quote
