04-22-2017, 10:13 PM | #1 |
who has done a frame swap?
what frame would a 62 swap onto the easiest/best fit? how involved was it? what had to be done?
04-22-2017, 10:18 PM | #2 |
But Found Her 25yrs Later!
Re: who has done a frame swap?
62 will fit best on a 60-62 frame.
2nd best would be 63-66 3rd 67-72 73+ isn't worth the work. And it won't sit right anyway.
04-22-2017, 10:28 PM | #3 |
Years ago, before I knew better, I put my totaled 65 on a 62 frame.
The front cab mounts don't line up, and the bed mounts are further apart on the 60-62 because the frame gets wider in the back. Also, the front frame horns are different = the bumpers won't interchange. Not too much work to put a 62 on the 63-66 frame.
04-22-2017, 11:20 PM | #4 |
60-66 Nut
In Washington state, I would suggest checking with your local DMV or WSP and ask what is needed to make a frame and body swap legal in your state. You will have a truck that has a different VIN on the cab than the VIN on the frame.
