Old 04-28-2017, 10:48 PM   #1
Wwes
83 K10 Survivor Project
Just picked up this 83 K10 to perform a full restore on it. Always wanted one of these trucks. Paid $500 for it.
The body is in great shape, only minimal cab corner rust. Some dents to handle. Needs a full repaint.
The interior is pretty rough, but it's all there.
The engine is the 305 with a TH350 transmission. Runs good thus far.
This one seems to have all the options as well
And finally, here's my other two GM trucks. Sold my 97 a few years ago and miss it daily.
Goals: Fresh paint, fresh interior, probably drop a built 350 with TBI (pref. factory style). Considered LS swap but want to keep it pretty close to period.
Will my spare set of tires from my new truck fit on this one?
Hope you all follow along as I dig into this and turn it into a stock show truck.
Wwes is offline   Reply With Quote
Old 04-29-2017, 02:47 PM   #2
dragonball98312
dragonball98312's Avatar
Re: 83 K10 Survivor Project
Unless someone swapped transmissions your options list says its a 4 speed, most likely a 700r4 not th350 which were only 3 speeds
dragonball98312 is offline   Reply With Quote
Old 05-01-2017, 11:51 AM   #3
Wwes
Great, it must be the 700R4 just going off what I was told but it hasn't been changed yet.
Still trying to figure out what part to tackle first. Any suggestions?
Old 05-02-2017, 10:36 AM   #4
trucknut85
trucknut85's Avatar
I have a 1985 K10, and the aftermarket wheels off my 2007 Silverado fit just fine.
trucknut85 is offline   Reply With Quote
Old 05-02-2017, 04:59 PM   #5
Wwes
Thanks, I'm going to get them on there soon. I have so much to so with it I'm overwhelmed! but very pleased its original.
Old 05-02-2017, 10:52 PM   #6
abig84
abig84's Avatar
Have to crawl under and look at the shape of the trans pan or post a picture of the pan and someone can tell you what it is. Every old 80s Chevy except one someone swapped out the 700r4 for a th350.
Great find and great price I would have bought that truck with no windows bald tires and no drivetrain for 500 bucks
abig84 is offline   Reply With Quote
Old 05-02-2017, 11:19 PM   #7
Wwes
I was going to swap the engine with a 350. Tonight the wife asked me to start it up for her, it has been sitting since last Thursday. Two cranks and fired right up. Think ill clean her up and keep the engine for now.
Old 05-05-2017, 06:33 PM   #8
Wwes
Decided on how to handle this project -
1. Suspension/Brakes/Exhaust
2. Body Work
3. Interior work
No engine/transmission in there, as I've decided to leave as-is for now. Just minor maintenance, starting with valve cover gaskets, A/C rebuild, and hoses/belts.
Today I checked that engine runs on both gas tanks. Seemed to work fine, a little extended cranking when switching but that's what I expected.
Here's the transmission. Looks like it had a major oil leak from the valve covers or rear intake gasket. Going to start tearing it apart next week and replacing them.
Any ideas on why the fuel gauge is on full? Suspect it might be a ground issue but not sure. Also, the volts gauge doesn't show any activity either, so need to figure that one out. Good oil pressure though.
Eventually I want to put these wheels/tires on it off my 2011 until I can have the original wheels powdercoated. The lugs aren't long enough, but they do fit. Will get new lugs pressed in.
Old 05-05-2017, 11:25 PM   #9
abig84
abig84's Avatar
Looks like a th350. The pan is a square with a corner cut off of it. 700r4 is pretty much a square.
Usually on these old trucks when the gas gauge goes way past full it's a bad/broken ground at the tank.
Not sure if you can get at the ground with the tank up on a pick up, never had to mess with mine on the k30, on many k5s though
Old 05-06-2017, 10:17 AM   #10
Wwes
Will check on the ground - thanks
And that makes sense about the transmission. I found the torque-converter lock up pigtail hanging down by the drivers' side exhaust manifold - and no where to hook it up.
Old 05-09-2017, 04:12 PM   #11
Wwes
Still here, still working on it. I've determined the valve cover gaskets and the rear of the intake gasket are leaking, so the top half of the engine is tore off.
Local shop said radiator and alternator are both junk - not surprised.
And now, I've gotten this far in the teardown I am considering a crate 350 from GMPP. A local transmission shop quoted me $2000 for a late 700R4 installed, fully rebuilt.
Old 05-10-2017, 10:52 AM   #12
Jstock85
$2000??? I paid $600 for a th350 to be rebuilt and put it in myself. I understand thats a different transmission but that seems kinda high.
Jstock85 is offline   Reply With Quote
Old 05-10-2017, 12:40 PM   #13
Wwes
After I did some research I found it to be double what I expected to spend on it. Not going to happen.
Glad to see someone following this build - thought I was wasting my time.
Old 05-10-2017, 12:43 PM   #14
daddyjeep
daddyjeep's Avatar
I'm still here too.
I like those wheels. They fit without adapters? I was thinking the newer truck would be metric.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 05-12-2017, 08:54 PM   #15
Wwes
Great, glad you guys are following. The new wheels fit fine but the studs weren't deep enough to get a good bite on the lugs.
I found a good deal on a takeout 350 TBI setup. Or I can get a 350 Vortec for the same price, and put a TBI on it (and order the TBI Vortec intake for $450). Assuming price doesn't matter - which would you do?
Old 05-14-2017, 09:01 PM   #16
ACS
The vortec is a roller lifter motor. That's what I would do...
ACS is offline   Reply With Quote
Old 05-23-2017, 09:51 PM   #17
Wwes
Still haven't got the engine deal worked out yet - so I put new valve cover gaskets on the 305, had to replace some vacuum lines, and got it fired back up. I removed the 4BBL and it was gummed all to hell, so I sprayed it out real well and now the choke seems to be sticking. It's running about the same though.
Old 05-23-2017, 09:54 PM   #18
Wwes
Also got a new radiator put on, and the Alternator as well. The core support has some rust on the bottom so it will be replaced.
The choke light it on at the dash. What does this mean?
Old 05-26-2017, 09:56 AM   #19
Wwes
Spent last week doing a few tasks - first, the brakes. Rear drum brakes were shot, one cylinder was blown out. I replaced everything inside both of them and repainted the drums.
Then I decided to restore the original wheels. Sandblasted them down and repainted the center in black and repainted the lip in metallic silver. It looks a lot better and will work for now. Finally, had them wrapped in BFG AT for the classic 80's look.
Now it's running rich and I'm exhausted trying to figure this carb thing out. Will spend the weekend looking for a new engine/transmission combo.
Old 05-26-2017, 10:57 AM   #20
Jstock85
Progress! Looks good.
Old 05-26-2017, 06:31 PM   #21
Zachary17
Zachary17's Avatar
Nice Truck! does the choke light stay on when the engine running? Or does it go out.
Zachary17 is offline   Reply With Quote
Old 05-26-2017, 10:10 PM   #22
Wwes
The choke light is always on. Thanks for following guys, makes it worthwhile.
Old 05-26-2017, 11:45 PM   #23
Zachary17
Zachary17's Avatar
if the choke light is on all the time than you have no power at the choke.the dash light should turn off as soon as you start the truck if the choke has power.
Old 05-27-2017, 01:27 AM   #24
MTCK
MTCK's Avatar
Cool project. Another vote for the roller motor.
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 05-27-2017, 07:19 AM   #25
Mr.Chevy4x4
Mr.Chevy4x4's Avatar
Check to see if there is a spacer between the transmission and transfer case adapter. If so, then the driveshafts are already the correct length for a 700r4 or 4l60e. My vote is for a late model 5.3/4l60e swap. This would make the truck daily driver reliable. You can pick them up fairly cheap and it's not a terribly difficult swap. You could probably buy the engine and trans and do the swap for not too much more than they quoted you for the 700r4 swap (if you do most of the work). Would also improve the fuel mileage greatly. Just my $.02.
Cool build either way. That's always been one of my favorite color combinations. Keep it going!
Mike
All things Chevy truck:
1986 SWB "Jolene" boosted 5.3/4l80e project
Mr.Chevy4x4 is offline   Reply With Quote
