Old 05-03-2017, 03:05 PM   #1
64jmb
64jmb's Avatar
1966 C10 Turn signal question and issue
Hey All,
I replaced my turn signal switch recently and also the plastic return piece on the back of the steering wheel as well with a NOS one. I have had 2 new turn signal switches installed in the last 6 months... both are acting up. Half the time they do not want to work, and my mechanic told me that his supplier told him this is a normal thing that they are finicky and never ever really worked correctly.... is anyone else having this issue? What can I do to resolve it? Is there some trick I am missing to correct this? Let me know. thanks
64jmb is offline   Reply With Quote
Old 05-03-2017, 03:24 PM   #2
shp4man
shp4man's Avatar
Re: 1966 C10 Turn signal question and issue
What specifically are they doing or not doing? No flash, no lights, no cancel?
Everybody has to believe in something. I believe I'll have another beer.
shp4man is offline   Reply With Quote
Old 05-03-2017, 03:47 PM   #3
Clyde65
Clyde65's Avatar
If they are aftermarket, that's the quality that's out there unfortunately.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 05-03-2017, 04:22 PM   #4
forestb
forestb's Avatar
have you tried the expensive Ac-Delco brand?
forestb is offline   Reply With Quote
Old 05-03-2017, 04:30 PM   #5
64jmb
64jmb's Avatar
I am not sure of the brand ... I turn the signal left or right and half the time it will not flash... then I have to giggle it around. The aftermarket ones that have been put in are a issue for sure.
Does AC Delco make one? Is that after market? If so where?
OR OEM NOS?
Old 05-03-2017, 04:40 PM   #6
shp4man
shp4man's Avatar
Flasher?
Old 05-03-2017, 04:53 PM   #7
64jmb
64jmb's Avatar
I meant the turn signal indicator lights in my cluster on each side as it is clicked to what side I am using. Not a emergency flasher... sorry for the confusion.
Old 05-03-2017, 05:22 PM   #8
shp4man
shp4man's Avatar
Alright, so there's a round thing about the diameter of a quarter, inch long, mounted on the bottom of steering column upper area, right side-orange and white wires (if it's the same as a 65?)... that's the flasher. If it's toast, signals wont work. That's the thing that goes dink...dink...dink when you turn on the signal.
Or are you saying the green arrows in the cluster aren't working, but everything else is?
Old 05-03-2017, 05:40 PM   #9
64jmb
64jmb's Avatar
ok my entire wiring harness has been replaced in the whole truck including all the wiring in the steering column. So I do not know if that part is still there... sometimes I have to push it in a bit to get it to work... would it still be there if the harness was all replaced? The harness I used was a generic one not a factory one... it worked out great!
Old 05-03-2017, 05:53 PM   #10
64jmb
64jmb's Avatar
I don't know if the outside is working when the green light indicators are not on... what is the part called at the end of the column? orange in color size of a quarter....Would that be replaced in the harness replacement?
Old 05-03-2017, 06:22 PM   #11
shp4man
shp4man's Avatar
I dont know if a replacement harness has a turn signal flasher. Sorry, thought you had factory wiring.
Old 05-03-2017, 06:25 PM   #12
64jmb
64jmb's Avatar
It did this before I replaced it as well. Not work correctly.
