05-10-2017, 01:39 AM | #1 |
Ls Swap question
I have a question, I got a 4.8 for my c20 daily driver. And the question is should I keep both O2 sensors or just the one in the front? What else should I keep from the wiring harness for a daily driver? Thank you guy any help is appreciated .
05-10-2017, 02:56 AM | #2 |
Re: Ls Swap question
most people do a rear o2 sensor delete..you may not be able to where you live..you'll need the complete engine harness if your plan is to rework it..if your buying aftermarket harness you won't need it..I used psi harness and it calls for a different p/n o2 than what the donor truck came with
05-10-2017, 09:24 AM | #3 |
Just the front 2.
Lt1swap.com has all the information you need. also you tube "project rowdy" That guy is putting a 5.3 into a jeep and walks you through his harness and engine rebuild. I too have a 4.8 I'm putting into an 85 c10. Those plus the knowledge on this board will be about all you need to work the kinks out. What transmission are you using? |
05-10-2017, 12:10 PM | #4 |
What's wrong with keeping the rear 2 (as long as you still have the cats, of course)? That's how they ran factory... and that's how the LS3 runs in my 69 Camaro. All 4.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
05-10-2017, 12:56 PM | #5 |
I don't think there is necessarily anything wrong with keeping all 4, I think for swap purposes you only need the from 2 for the PCM. I don't think people usually swap exhausts with cats and stuff all that is usually custom
05-10-2017, 05:03 PM | #6 |
if no cats then no need for rear 2 O2's
05-10-2017, 07:11 PM | #7 |
meowMEOWmeowMEOW
If your doing your own harness, I'm not against keeping the rear o2 pigtails. It lets you run downstream sensors if you ever do choose to run a catalyst. The wiring itself can be tucked away.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
05-11-2017, 09:05 PM | #8 |
I bought a 2001 silverado low miles to put in engine and trans into my 1970 c20. I think is a 4L60e. Thank you for all the info I ask because project rowdy only kept one set of O2 sensors.
