05-13-2017, 10:41 AM | #1 |
Intro and OEM fan set-up question for 1988 454 one ton dually
Hi All - Dave here, new to this forum. I have a few older trucks, but I am working on two late 80s square body one ton 2WD Dually rigs.
One of the rigs is a 1988 Camper Special that was missing its engine and tranny when I bought it. I swapped in a 454 TBI that was readily avaialble and all is running well. I am now working on the A/C hook-up and I am tackling the A/C condensor and radiator shroud area to ensure I have the right cooling set-up. I am struggling finding a replacement radiator fan shroud and I am scratching my head at this point. So, here's the question: Is it possible that this truck had an OEM Electric radiator and a/c condensor fan set-up from the factory? Thanks a ton in advance. Dave
1988 Crew Cab Dually 1989 Crew Cab Dually |
05-13-2017, 12:56 PM | #2 |
Re: Intro and OEM fan set-up question for 1988 454 one ton dually
No it would have been a mechanical clutch fan with a shroud.
05-13-2017, 03:36 PM | #3 |
The shroud assembly is a unicorn. I ordered replacement pieces from LMC for my 89 (both the shroud + radiator top cover) & neither was correct/matched the OE stuff. I just had to clean up my OE stuff & go w/it.
05-14-2017, 11:19 AM | #4 |
Thanks for the follow-up. My thought at this point is to buy a new radiator (planning on it at some point anyway) and match the aftermarket shroud to that. Is this possible or am I up against the same issue?
Thanks again, Dave
05-15-2017, 12:49 AM | #5 |
In the Forgotten far North.
Factory setup with a.c. would have the water pump mounted clutch fan and shroud as well as a small auxiliary electric pusher fan mounted to the frontside of the core support on the passengers side.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
