Old 05-18-2017, 12:53 PM   #1
NoNeck
NoNeck's Avatar
Fuel Line Bending Tip
After collapsing my share of metal tubing over the years I came up with a shade tree solution that worked for me. I had a length of braided accelerator cable left over from an earlier job. I inserted the cable into the full length of the fuel line that I was bending. The bends came out perfect and the cable was easy to pull out after all the bends were made.
I know there are other tricks out there for bending fuel/brake lines, but I really like this one.
POP
2016 RAM Laramie HEMI
1966 Fairlane GT/A, 390/335 HP
If it costs you a dollar to make a friend, KEEP THE DOLLAR.
If it costs you a friend to make a dollar, KEEP THE FRIEND.
NoNeck is offline   Reply With Quote
Old 05-18-2017, 01:07 PM   #2
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Thumbs up Re: Fuel Line Bending Tip
Smart!
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
Old 05-18-2017, 02:10 PM   #3
57larry
or you could use a tool that bends tubing
57larry is offline   Reply With Quote
Old 05-18-2017, 02:22 PM   #4
toolboxchev
Nice, follows the same principle of mandrel bending. I was borne on a farm, and it serves the necessity of the mother!
toolboxchev is offline   Reply With Quote
Old 05-18-2017, 04:24 PM   #5
cleszkie
cleszkie's Avatar
X2. I have never had an issue with collapsing steel brake or fuel line when I use my tubing bender tool.
cleszkie is offline   Reply With Quote
Old 05-18-2017, 02:39 PM   #6
leddzepp
Moderator
leddzepp's Avatar
Pretty slick
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 05-18-2017, 02:47 PM   #7
Rolland
Great idea and easier and less messy than filling line with sand.
Rolland is offline   Reply With Quote
Old 05-18-2017, 03:05 PM   #8
fatbass
fatbass's Avatar
Great idea! Add it to this thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=486889
'71 C/20 350/T350.
fatbass is offline   Reply With Quote
Old 05-18-2017, 06:58 PM   #9
NoNeck
NoNeck's Avatar
I use a tube bender that I bought from Summit Racing years ago. I have never been able to bend a very tight 90° without some form of tubing collapse. When using this method all of my bends stayed open and free flowing.
POP
Old 05-18-2017, 10:22 PM   #10
Steeveedee
Who Changed This?
Steeveedee's Avatar
POP
That must be a better version than the one I bought at O'Reallys. Mine is a real POS that will kink a line in a heartbeat, unless you fiddle with it a lot. I've had better luck using a couple of box end wrenches.
~Steven
Simi Valley, CA
Old 05-18-2017, 10:29 PM   #11
In The Ten Ring
POP
I have the same tool (linked by a member here) and after a certain angle, all bends are kinked. The accelerator cable idea is one I may copy, thanks!
In The Ten Ring is offline   Reply With Quote
Old 05-18-2017, 11:23 PM   #12
Metaldoc
Metaldoc's Avatar
I've bent tube by filling with water, freeze it and bend it.
Metaldoc is offline   Reply With Quote
Old 05-18-2017, 11:33 PM   #13
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
I have a tubing bender made by Mac Tools. It is made out of a pretty tuff nylon material. Makes great bends with no kinks at all. Here is a 3/8" fuel line I bent up and had one bend well past 90 degrees.
Kind of a bad pic of the bender, but it's the only one I have on file here.
Fuel line.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 05-19-2017, 12:47 PM   #14
GRX
GRX's Avatar
Good simple solution.
Couple of mine are using Ni-Copp line that is extremely easy to bend. And when working with steel, use of a torch to anneal the line to eliminate work hardening from the production process. Makes bending & flaring much easier. Not good for coated lines of course.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 05-19-2017, 02:09 PM   #15
lolife99
67-72 parts collector,…
lolife99's Avatar
This is a great tip for someone with out a bender.
But bending tube is only as good as the bender you use.
Buy the best bender that you can afford.
(and flaring tool also)
Keith
Convert to disc brakes.
