![]() Join Date: May 2010
Engine Oil Ranking
I've seen numerous threads here about which oils are OK to use in flat tappet and high performance engines. Most tend to recommend oils with high levels of ZDDP. A friend has a bunch of oils from the late 1990s. This prompted me to search for more info on ZDDP levels in today's oils. The link below, from 2015, provides interesting info on ZDDP oils and wear protection. Obviously, I have no information on the author's credentials.
Comments??? http://www.sccoa.com/forums/showthre...*Good-read***& |
![]() Join Date: Jul 2015
Re: Engine Oil Ranking
Here are the facts, from my perspective.
Complete top end rebuild 70,000 miles to date. Comp cams break in additive for first 5,000 miles. From there on out I have been running Valvoline VR1 non stop changing the oil every 2,500 miles. So far so good, when I tear the engine down for the bottom end, which is in the near future will know more. For what its worth... The zinc ratings from that website are subject to ones own inspection. Valvoline sds sheets show 1.09 percent ZDDP. Or check this link: http://content.valvoline.com/pdf/vr1_racing.pdf Even though I do not work for them or any oil distributor or auto parts store in any way that makes for a heck of a sale. |
I add a bottle of Lucas Break-in oil (high zinc content) at every 5,000 mile oil change with conventional Castrol oil, and I have a full roller engine! I figure if its beneficial for flat tappet set-ups, it can't hurt a full roller.
![]() Join Date: Feb 2001
Here is some reading for you ...
Which is the best Motor Oil http://67-72chevytrucks.com/vboard/s...ad.php?t=27522 What type of Motor Oil do you use. http://67-72chevytrucks.com/vboard/s...d.php?t=462211 Favorite Motor Oil http://67-72chevytrucks.com/vboard/s...d.php?t=178372 What Motor Oil do you use http://67-72chevytrucks.com/vboard/s...d.php?t=231343
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
#5 | |
#6 | |
Who Changed This?
![]() Join Date: Jan 2013
#7 | |
14.1 @ 96MPH
I won't buy a Fram orange can, but only because they charge too much for what it is. Any other manufacturer at the same price (Wix, Motorcraft, etc) is better quality, and you can get the same quality for a fraction of the price (Pronto, etc) from Rockauto.
Project1970 - LS1 Swap Complete! ![]() |
![]() ![]() Join Date: Feb 2009
I just started using Mobil 1 5W30 full synthetic on my 71. Technically one oil change. I did the same for my 72, but the engine is a bit tired & burns oil, so the next change is the same only 10w40. Couldn't tell you how zinc starved the original engines are. Mobil 1 is declared "900 Nominal Zinc Level, PPM". I have no idea what that means. I can say I used one bottle of ZDDP, read something I didn't like and changed it the next day. There are lots of opinions.
Here's a great study, if nobody has posted it yet. https://540ratblog.wordpress.com/201...-test-ranking/
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
I used FRAM for years with no issues.
My only issue with Fram is the perception that if AutoZone recommends it, it's probably not that good. So, I'm running Wix now, simply because they make NAPA's house brand. I change the oil/filter every 3k miles with Havoline 10w40. No zinc additives, since the engine has over 30k miles on it and is well past the break-in period.
72 K2500 Sierra Longbed Wideside 350/TH350/NP205 66 Plymouth Barracuda 225 Slant6 |
A bit of my own experience: I had a flat tappet engine re-built, and used modern, hig-qulaity oil, only to discover that only a few thousand miles down the road, the cam had deteriorated, with a couple of the lobes being almost flat. I had a new cam installed, and from then on, I used a Lucas Oil additive, with high zinc content, and those troubles went away. My 69 is the only vehicle I have without roller tappets, and I'm using Mobil1 5W-30, and it seems to be doing well. The previous owner used Valvoline 20W-40, so perhaps the cam/tappets got off to a good start.
Against conventional wisdom, I installed new lifters on the old cam, slathered with huge amounts of assembly lube, and so far, so good. The cam lobes appeared perfect at that time. We'll see what develops. Frequent changes, proper warm ups, and so on can't hurt at all. Neither can buying quality oil and filters.
Rick -69 GMC 910 Long Box, 350 -98 Chev Silverado 1500, 350 Vortec 4L60e -08 Mustang GT Convertible |
Do yourself a favor and read the 540rat blog mentioned above. Changed my perspective not only on ZDPP, but also change intervals, and additives.
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i |
![]() Join Date: Feb 2013
I would recommend taking the 540 rat blog with a grain of salt... I read the thing about a year ago and after reading I asked myself what I learned and if if I could duplicate his tests. the answer is a big fat no because he does not tell you anything about anything... not scientific and not sighted in any way...
If i were to write a 100 level college paper and used the blog as a primary source I would have gotten a big fat F... I have a History degree not science. I leave the biology to my wife, she has the BS degree, I know how to research. Anyway, IMO if you can write a mile long paper about scientific research and never sight a single thing and not outline the test procedures, you might as well be reading Harry Potter. |
I wonder what the oil temperature range is for the original engines? I ask because from the 540rat it reads:
9. 5W30 Mobil 1, Advanced Full Synthetic, API SN, GM dexos 1 approved = 117,799 psi zinc = TBD phos = TBD moly = TBD This was the latest current version of this oil when tested at the end of 2015. This oil is used by a number of Auto Makers worldwide as factory fill oil in their High Performance cars. The psi value of this oil, which came from testing it at the normal operating test temperature of 230*F, put it in the INCREDIBLE Wear Protection Category. [U]However, I went on to also test this oil at the much higher temperature of 275*F. At that elevated temperature, any hotter and thinner oil is expected to experience a drop in Wear Protection Capability. And this oil did have a disappointing 36% drop in capability.[/U] At that reduced value down to 75,861 psi, this much hotter and thinner oil dropped down to the GOOD Wear Protection Category. You can avoid such a drop in capability by keeping the oil at a more reasonable cooler temperature. Granted it says "normal operating temperature", under what conditions would it be abby-normal high operating temperature?
