Old 05-24-2017, 12:49 PM   #1
NaturalSnapple
NaturalSnapple's Avatar
Hydroboost conversion clarification
Hello all,
I'm doing a hydroboost conversion on my 71 with manual brakes. I have a hydroboost/master combo that I pulled from a 90's 2500 Van that had front discs and rear drums, just like on my C10, but there was no proportioning assembly.
Can I run this master without an additional proportioning assembly since the van it came off of was disc/drum just like my C10?
NaturalSnapple is offline   Reply With Quote
Old 05-24-2017, 01:17 PM   #2
demian5
demian5's Avatar
Re: Hydroboost conversion clarification
Did it go through an ABS module? If so, that was the porp valve.
I'd swap the master to an older style.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 05-24-2017, 01:18 PM   #3
NaturalSnapple
It didn't look like it. The hard lines connected to the master ran directly under the van along the firewall area, and there wasn't any other module in between.
Edit: Could I use the prop valve off of my manual brake assembly?
Old 05-24-2017, 02:15 PM   #4
Bigdav160
Bigdav160's Avatar
I don't see why not.
The van might have had the ABS module underneath. There's not much room in the engine compartment.
Which fittings are you using for the hoses?
I need to start on my conversion soon.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 05-24-2017, 02:20 PM   #5
NaturalSnapple
You're right, it may have been underneath the firewall.
I plan on using a later-year power steering pump so that all the fittings are metric, and then have my local hydraulics shop make the lines for me. I don't have power steering (yet) so this takes a lot of the guess work out of it.
