05-30-2017, 09:16 AM | #1 |
Pictures of steering column
Hope it works now
05-30-2017, 09:45 AM | #2 |
Re: Pictures of steering column
Hi guys!
The pictures show my new column and PS Box. I mount a new rag joint and my old couple on the box. The shaft comes with the column and I let it run trough the old shaft. The spring and washer is from my old steering. I don't know if this is working, but it looks right, or? Should I drill the two holes on the shaft and fastened it? My question is simply: Does this make any sense to you? Need feedback. |
05-30-2017, 11:36 AM | #3 |
That is a collapsible shaft in the case of a collision and it's supposed to look just like that.
05-30-2017, 01:24 PM | #4 |
05-30-2017, 12:51 PM | #5 |
Looks fine to me sir!
Project NewType 1972 Chevy C/10 Cheyenne Super ( Daily Driven Showtruck ) http://67-72chevytrucks.com/vboard/s...d.php?t=507903 Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289 - Dylan (209)-985-7721 |
05-30-2017, 01:20 PM | #6 |
05-30-2017, 01:32 PM | #7 |
Yes it's drive able. And no, don't drill holes and fasten it. If anything take it back off and put a little bit of grease on that shaft so in case of a collision the shaft collapses instead of staying put and injuring you.
1967 Chevy C20 to K20 Conversion "Simply Toxic" http://67-72chevytrucks.com/vboard/s...d.php?t=749409 1971 Chevy C20 Custom Camper LS Swap http://67-72chevytrucks.com/vboard/s...d.php?t=763775 |
05-30-2017, 02:29 PM | #8 | |
Should I put it on the end of the shaft instead? Now the shaft is lose inside both the column and the intermediate shaft. |
05-30-2017, 05:14 PM | #9 |
I believe the spring is intended to hold pressure on the bearing cup, bottom of column, spring, washer, clamp.
05-30-2017, 02:19 PM | #10 |
