Old 06-04-2017, 10:23 AM   #1
Slik66
Slik66's Avatar
Frame flex question?
I am building my truck to drive good, handle some twisty roads and put the power to the ground. In my research I have found several people installing "X" bracing in the frame.
My question is: what Exactly does this do and is it needed to keep flex down?
Is there a different way to do it?
It's what you learn After you know it all that counts!
Slik66 is offline   Reply With Quote
Old 06-04-2017, 12:15 PM   #2
LVPhotos
LVPhotos's Avatar
Re: Frame flex question?
The guys on Trucks tv did a Ranger that addressed this. Take a tire jack it up and you will see frame flex. The X like 60-62 frame stiffness frame to counter such flex. Unless racing or ridiculous hp and torque it over kill.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 06-04-2017, 12:40 PM   #3
Slik66
Slik66's Avatar
Right now my new engine is 440hp and 460tq.
BUT.... I have plans for the future to swap to an engine in the 600hp range.
I just want to do things Now while it's all apart. Just not sure what's I really need to do to keep it tight and straight on the road
Old 06-05-2017, 07:14 AM   #4
PGSigns
PGSigns's Avatar
Couple of things you can do. One is stiffer cab mounts. This lets the cab do some of the work to stiffen the chassis. If you want a bolt in solution the porterbuilt is a well engineered piece. If you look at what Rob at NoLimit has done with the Pro-tech chassis you can see how they have added a lot of torsional stiffness.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 06-05-2017, 07:41 AM   #5
Slik66
Slik66's Avatar
Thanks!
Old 06-05-2017, 09:56 AM   #6
padresag
if things can't flex; they break
ron
padresag is offline   Reply With Quote
Old 06-05-2017, 07:52 PM   #7
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Take a look at Gary V's build. I think he has X bracing figured out.
http://67-72chevytrucks.com/vboard/s...d.php?t=625387
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 06-05-2017, 08:41 PM   #8
Slik66
Slik66's Avatar
Wow, what a build!
Old 06-06-2017, 12:10 PM   #9
scoot_mcgrute
When I had my frame apart, I should have done a little more research and done some bracing/boxing on it. When I put it on jack stands at either end, it sags in the middle a fair amount, more than I'd like to admit .
I'm doing the same things that you are looking to do with yours but without the bracing and boxing. If you plan to have a lot of fun with it whether it's on twisty roads or in autocross events, I wouldn't hesitate to make it stiffer. My next frame will definitely have more thought put in to making it work for autocross and track nights.
1966 Army Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=691778
scoot_mcgrute is offline   Reply With Quote
Old 06-06-2017, 01:00 PM   #10
Slik66
Slik66's Avatar
Twisty roads for sure!
Old 06-06-2017, 04:50 PM   #11
tinydb84
tinydb84's Avatar
Read this thread. Rob from No Limit does a budget build with a 67-72 but you can use most of the ideas.
http://67-72chevytrucks.com/vboard/s...d.php?t=436621
David
Instagram: myfabguy
Old 06-06-2017, 05:03 PM   #12
Slik66
Slik66's Avatar
Man, great info in that thread!! Thanks!
Old 06-07-2017, 07:40 AM   #13
Keith Seymore
Keith Seymore's Avatar
Are you opposed to a full roll cage?
That would provide the most resistance to flex.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 06-07-2017, 08:07 AM   #14
Slik66
Slik66's Avatar
I don't want a full cage. I just really wanted to beef the frame up a little while I was at this point.
I think my biggest concern is traction.
Old 06-14-2017, 10:43 PM   #15
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Side question:
Does stiffening the frame stiffen the ride?
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 06-15-2017, 10:27 AM   #16
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Originally Posted by LostMy65 View Post
Side question:
Depends on your suspension setup. If it was already too stiff and the frame flex "soften" the ride, then stiffening the frame would cause it to ride stiffer. When you can get the frame flex under control, you can then setup the suspension to work as it should but you might end up with softer spring rates and different valving in the shocks. The biggest thing about eliminating frame flex is you allow the suspension to actually do what it's supposed to be doing.
Most companies figured this out in the '90's and started to stiffen up the frames. Look at a modern day truck and those frames are seriously beefy.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
