Old 06-05-2017, 12:35 PM   #1
michael bustamante
michael bustamante's Avatar
Ac. Compressorr issue
Why is my compressor engaging and then dis engaging the clutches every few seconds?
99 sonoma. 4.3
Trying to add freon and nothing...
1967custom
michael bustamante is offline   Reply With Quote
Old 06-05-2017, 01:10 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: Ac. Compressorr issue
Have you tried to add freon lately?
Usually undercharging will do this but over charging will also do it. Best way to see if it's overcharged is to hook it up with a full set of a/c hoses to check the psi on high and low sides -static and idling or running.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 06-05-2017, 01:45 PM   #3
michael bustamante
My guage shows full safe. Not overcharged. But full full
1967custom
Old 06-05-2017, 04:44 PM   #4
68gmsee
Active Member
68gmsee's Avatar
If it started doing this after you recharged it, it may be overcharged. Barring obstructions or defective compressor cycle switch, the best way to find out if it's over or under charged is with set of a/c manifold gauges. I would do that first even if I had to have a shop test it before tearing into the system. You can run into unnecessary expense if compressor is damaged.
06 Trailblazer
Old 06-06-2017, 09:09 AM   #5
Dead Parrot
Possible the orifice tube filter is mostly plugged. The moment the compressor cycles on, it over-pressures and the high pressure switch cuts out.
2nd the suggestion to use a dual set of gauges to test.
Dead Parrot is offline   Reply With Quote
Old 06-06-2017, 12:08 PM   #6
michael bustamante
Yup im gonna have to hook up guages. Any idea where the oraface tube is on a 4.4 vortec. 99 sonoma
1967custom
Old 06-06-2017, 05:30 PM   #7
68gmsee
Active Member
68gmsee's Avatar
It's for a 2000 but it probably is in the same location. This guy on youtube ain't too happy with the Sonoma engineers. Orifice tube is under the accumulator cannister.
https://www.youtube.com/watch?v=aXz5jxDLgZ0
06 Trailblazer
Old 06-15-2017, 09:33 PM   #8
michael bustamante
oh jeez really? as soon as I add Freon it starts doing that crazy clutch thing. I bet the tube is contaminated
1967custom
