Can I go first?
![]() Well, first of all, backing out of the garage the ignition switch started smoking and so I had to fly out of the truck, grab a wrench and rip the battery cable off. ![]() The next thing; after replacing the switch, doing a bunch of work on the exhaust, fixing a transmission leak and installing a proper crossmember, I took it out for a test drive and then the horn decided to come on full blast and keep on beeping regardless of pounding on the button. Yeah Beotches, get outta my way!!! ![]() So I had to pull over and rip the horn wire off. I can't wait to see what happens next. I hope it's nothing to do with the brakes. ![]() ok, I'm done, someone else go ..... and make it good! ![]() |
Re: Funny things you found out about your truck after you bought it....
From the old receipts I found in the truck, I saw that The second owner had the engine rebuilt at 109k miles. Do to dropping two lock washers down the intake, I rebuilt the engine at 159k. The machinist asked me to bring the old bearings to determine a starting point for boring.
When I handed to him, he had this puzzled look on his face. They were factory bearings! Then he checked the cylinders, and they were between .010 and .028 over. I just said wow. Then I showed him the receipt for $2800, that it cost for the "rebuild". I was fortunate to have an old Drag Racer guide me through my complete rebuild. |
#3 | |
Who Changed This?
![]() Join Date: Jan 2013
At the body shop.
The complete hodge podge of 1/2t and 3/4t parts and an unknown dana 60.
Rusty cab, perfect bed.
" That didnt make it any newer " " Dont antique the equipment " |
Five hundred dollars in cash neatly tucked in an envelope and sandwiched in the seat springs. Looked like it had been there for many decades and the old bills proved it.........
Steve weim55 Colorado |
#6 | |
![]() Join Date: Jul 2015
Funny things on mine, there were a ton. The stupid carpets glued to the vent sheet metal should have given me a sign. Glad I ripped those soaking wet things out immediately. |
#7 | |
![]() Join Date: Feb 2010
Location: Falls City, Nebraska "100 Miles From Nowhere"
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American" ![]() |
![]() Join Date: Jun 2009
I bought mine at night and after getting it home in the daylight I realized under the pretty orange shag carpet was a fiberglass floor and rockers
Larry It is easily overlooked that what is now called vintage was once brand new. "Project 68" paypal.me/ldgrant |
Sounds simple enough but it was only a week after I bought my truck that I had to replace the ignition switch. Now, for whatever silly stupid reason I took the one and only original ignition key that was in this little leather snap pouch and chucked it into the wood pile about 100 feet from where I was working.. It was months later while reading my owners manual that I learned the ignition key also opens and locks the doors! I said to myself you stupid mother@&*%^*&)*! I actually went out in my garage and started looking everywhere for that key forgetting I chucked it into the woods. Well, wouldn't you know it that about a year later while getting some wood for the stove with a foot of snow on the ground I come across this little leather snap pouch with one GM key inside! Long story short, I can now lock my doors!
#10 | |
Builds: Green Gus the 68 C10 ; Sullii the 72 1500 - Instagram: @dr.hewitt - C10 Concept/Development Photos: Master Thread |
The engine in my truck always had a "tick" since I bought it. Last summer I finally pulled the valve covers to check the valve adjustment and I find a socket extension under the valve cover. Removed it and the "tick" was gone. It did not appear to do any damage and I can only guess how long it spent under there.
#13 | |
He bought a motor home from a dealer, it is a diesel pusher. To access the top of the engine, he had to remove the mattress at the back of the coach. There he found an envelope hidden with $600 cash in it. He had probably had the thing for 2 years before he found it. Greg |
![]() Join Date: Aug 2015
After purchasing my "67" SB K10 stepside, I discovered that the engine is a 66, the frame/drive train is 70, and the fenders are 68.
Thanks to this forum I now know all the necessary details about all of those parts, but at the time of purchase I had no idea. What a difference a year makes. |
#15 |
This thread is great... where do I begin?
My '71 came with all the original paperwork. It was purchased new in Monticello, NY by a Ruth DeGroot. lol Original short bed, but the frame was cut behind the second bed mounts and a new? frame welded back on. Bondo literally everywhere. Inside the engine compartment, inside the cab, inside the bed. wtf? Cab mounts were shot. In fact, the rad support was not even attached to the frame. Took me quite awhile to realize lol I was 16 and it was my first car. |
#16 |
The bearing races on the passengers front wheel drum were welded to the spindle from heat. Nothing was holding that front wheel on except for the weight of the truck and friction from a few components. The spindle nut wasn't really holding anything together. It's a miracle the guy didn't kill himself or lose a wheel at speed.
Other fun things.... cylinder heads had 2 cracks each, all 8 cylinders were leaking oil, 5 cylinders didn't have seals on the valves. Opened it up, and the cylinders still had prominent cross-hatching, and there was no detectable lip on any cylinder. Oh, and the brake fluid was jelly. This was the guys "daily driver". |
#17 |
This was the bed floor in my truck when I purchased it.
#18 |
![]() Join Date: Dec 2012
I bought mine from a 91 year old gentleman and wondered why there was an explicit rap type CD in the stereo.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
#19 |
#20 |
Our 70 GMC K2500 Had hundreds of whole walnut shells in the front fender wells, inside the heater core, in the cab, on the intake manifold, and in every nook and cranny they would fit. This truck lived under a walnut tree for 25-ish years and the squirrels were hiding things away for those cold days..........
The nut meat and hulls were all gone from all of them, so not much left to rot (fortunately!)
1970 GMC K2500 Dis-use is harder on a car than mis-use. |
#21 |
![]() Join Date: Nov 2004
I've been lucky. My C10 was all original (including paint) with the interior hacked up for stereo & speakers. It had been in a minor wreck before (probably a deer as there was zero frame damage) and had a multi colored front clip on it when I bought it.
I guess the only "funny" thing was that it had one of those huge steel dealer bumpers on the back that said "Brownsville, TX" stamped on it (my last name is Brown). Wish I would have kept it. It's probably a Kia or toaster. I googled it and there is still a Chevrolet dealership there. Not sure if that's where my truck actually came from or not, but pretty cool. My only other experience was with a 65 mustang and it has been nothing but a pleasant surprise. Someone spent A LOT of money to keep it as original as possible so I could modify the hell out of it ![]()
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
#22 |
Not very exciting perhaps, but I was surprised to find that my grandfather had apparently crunched up the passenger rear bedside at some point. None of the rest of the family had any idea.
The body shop he took it to really laid the bondo on.
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
#23 |
Intake gasket cross over section was blown, leaking exhaust into the engine. - Replaced gaskets.
Header collectors were cracked. - New headers Heater core leaked. - New heater core Motor mounts were cracked. - replaced when headers were out. Tach was there but wires were never ran. - Ran wires Dash was covered in padded material, removed material to find two 4x6 speakers holes were cut into the dash and covered with aluminum can. - Covered again but looks much better. Windshield leaked at passenger upper corner (seal was recently replaced). - Sealed up. Carrier bearing broken from frame - replaced The icing on the cake. - I bought a GMC, but on the title says Chevrolet.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC Last edited by demian5; 06-07-2017 at 01:04 PM. |
#24 |
My 68 LWB had a cheap repaint when I bought it and after driving it for several years it became apparent there was bondo on the passenger side bed. I decided to see what was up with it and started removing the bondo to find the truck had been shot with some Buckshot. no holes all the way through but it sure stretched the metal.
2. later it became a fun fact that I had only paid $350 for the truck when I got it. several years later when my daughters date for prom had his car break down she wanted to take my truck. so she did wearing a $650 dollar dress her grandmother had bought for her. |
#25 |
I found a piece of 1" key stock about 3" long just sitting between the transfer case and cross member. The edges are all cleaned up and have know idia what it was for. I do know that clunk noise is gone.
AJC |
