06-11-2017, 06:48 AM | #1 |
Flowmaster Ram Horn down pipe? How long?
I'm changing from headers to angle back Ram horn exhaust manifolds. I found that Flowmaster makes down pipes (part #81072) but no one can tell me how long they are. I called everyone. Even Flowmaster Tech line could not tell me. I do have exhaust cut outs on my current exhaust system and would like to know if these pipes will reach. Any info will help.
Thanks. |
06-11-2017, 12:08 PM | #2 |
Re: Flowmaster Ram Horn down pipe? How long?
Following this also, are you going to install a cross over behind the down pipes ?
71 C-20 07 Magnum RT AWD |
06-11-2017, 12:12 PM | #3 |
06-15-2017, 06:56 AM | #4 |
They stop 20" from the first edge of the driveshaft crossmember about the center of the door. I can post pics if you need. I will say that they fit perfect and are tucked up as tight as they could be.
06-15-2017, 12:51 PM | #5 | |
70+ ( Old Skool Club )
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
06-15-2017, 07:59 PM | #6 |
Ram-Man thanks for the info. If you could post some pics that would be great.
06-17-2017, 08:55 PM | #7 |
Sorry for the delay not the best pics it's sitting low right now a good reference on length is the drivers side first pic they go about 4" past the factory double stacked rivet
06-19-2017, 05:34 PM | #8 |
It looks like the down pipes are going to work great! You can see by the picture the Exhaust Cut Out is before the two rivets. So the pipes are slightly longer then they need to be and I can just cut to fit.
Thank you for your help. |
06-19-2017, 09:19 PM | #9 |
No problem yes it looks like they will work great for you from your pic.
