Steering
Not sure if this is the way, feel free to coment.
Re: Steering
Did you dimple the steering shaft for the lock screw to set in?
Thread locker on the lock screws?
Re: Steering
![]() Join Date: Feb 2010
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: Steering
You need a collapsible link in there. If in the event of a front end collision bad things can happen to your face and chest area.
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American" ![]() |
#5 | |
Re: Steering
I bought this tilt steering column with this parts, and he told me nothing about a second link. Are you sure? |
Re: Steering
The first picture in his post is the part that collapses. That's why they have shear pins in them, not bolts.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
![]() Join Date: Mar 2003
Re: Steering
U-joint needs to go further onto the steering box to the next set of splines with the set screw in between
Re: Steering
Awesome catch there!
Re: Steering
I do quite a bit of custom steering and suspension work on all types of vehicles, trained eye.. And big pics on my monitor
#10 | |
Re: Steering
On my box there is a pin (you can't see it on the picture) on the top of the axel (spline) that I need to cut. Otherwise I can't get the U-joint in place as you prefer. To cut that pin isn't a big deal I suppose. It will not change the steering box function, would it? |
Re: Steering
Re: Steering
Yes, as long as it is installed correctly and is on all the way. How much engagement do you have with the Double D shaft and the slide?
Re: Steering
