06-23-2017, 08:32 AM | #1 |
66 Transmission Questions
Just bought a 66', 250 I6 with a 4 speed.
Shift pattern is R all the way to the right and down, which trans would that be? Any recommendations on an aftermarket shifter? Or can the factory one be rebuilt? It's super sloppy. Thanks |
06-23-2017, 08:52 AM | #2 |
Re: 66 Transmission Questions
cast iron granny geared SM420
06-23-2017, 09:04 AM | #3 |
Thx
06-23-2017, 12:18 PM | #4 |
reverse all the way to the right and down would be a 465
1961 chevy K10 my build is------------61K10 build |
06-23-2017, 12:57 PM | #5 |
Either uses the same shifter don't they?
06-23-2017, 06:42 PM | #6 |
Could also be the NP435
Current projects: 1966 Chevy Custom PS PB A/C BBW 283 v8 3 speed OD 1966 GMC Long Step 1966 GMC 3/4 ton Custom PS PB Sport trim 351 v6 1966 GMC 3/4 ton 4x4 Custom PB 305 v6 np435 1960 GMC Custom 1968 GMC 3/4 ton 4x4 Short Bed 1962 K20 Tow truck 1961 GMC Extended Suburban Panel and a few more |
06-23-2017, 11:16 PM | #7 |
60-66 Nut
With Reverse in that position it is either a SM435 or SM465. No such thing as an aftermarket shifter for either of those. You will have to remove the shifter from the top of the trans and see what may be loose.
06-24-2017, 08:28 AM | #8 |
I found the Novak replacement shifter. Ordered one yesterday.
Posted via Mobile Device |
06-24-2017, 09:07 AM | #9 |
that may not repair your problem though. that sloppiness comes from wear in the trans. all that wear is accumulative from over a 50 year span. the bottom of the shifter may have some wear, but that is just part of it. the piece it sits in will have wear as well as the piece it connects to.
it is more than likely time for a bearing and seal overhaul which is not that expensive. gives you a chance to replace the washers and that will effect end play. it also give you the opportunity to check the rest of the shifter mechanism for wear that shifter was also not a tight precision fit when it was new ron |
06-26-2017, 07:35 AM | #10 |
I'm a dumbass, reverse is to driver and down.
06-27-2017, 07:03 AM | #11 |
I do not want to steal the thread but mine is to driver and up. Since the topic is 66 transmission, any one know what mine is as well?
Thanks. |
06-27-2017, 11:50 PM | #12 |
60-66 Nut
Is it a 3 speed or a 4 speed? It sounds like a car 4 speed trans. I'm not sure about a Saginaw 4 speed, but with a Muncie or a BW T10, reverse is to the left and forward.
06-28-2017, 07:27 AM | #13 |
Thanks Captainfab. It's a 4 speed and I'd love it to be a Muncie but PO said it was a Saginaw. Just trying to confirm and it seems that shift pattern alone will not tell the whole story.
06-28-2017, 11:06 PM | #14 |
60-66 Nut
If the trans is cast iron and has all 3 shift levers on the side cover, then it is likely a Saginaw 4 speed. It has been so long since I have driven a Saginaw 4 speed, I just could not remember for sure where reverse was.
06-28-2017, 07:31 AM | #15 |
I'm guessing mine is a SM420, has bulldog first gear
06-29-2017, 12:43 PM | #16 |
they are the same as the t-10 and muncie.
07-04-2017, 02:37 PM | #17 |
Took the shifter out last night. It's broken loose at the ball, and the bottom piece has plenty of slop and broken welds where someone had welded it at the bottom before.
07-04-2017, 04:07 PM | #18 |
Not exactly sure what youre looking for but, sheesh! What you have explained sounds gnarly. These trans are damn near indestructible. Sounds like a PO has gone and fubar'd some stuff on you. Send us some pics of the damage so we can get a better understanding of exactly how bad your dilema is. Meanwhile, I found this on ehay:http://m.ebay.com/itm/Black-Painted-...257Ciid%253A18
Also, I did a search for sm420 (we have determined you are sm420 for sure?) all over Craigslist for the old cast 420. Nothing really going on nationwide. I did it for sm465 and it revealed many potentials around you within half a days driving distance. Maybe someone can chime in on me and tell us if the sm465 is a direct replacement for the 420 or do you need to adjust or cut things like driveshafts or the such. Good luck. |
07-04-2017, 04:17 PM | #19 |
Trans is working fine. Shifter was just shot.
07-04-2017, 04:18 PM | #20 |
That shifter in the eBay posting is the one it had on it. I got a one piece replacement shifter from Novak.
