06-24-2017, 06:46 PM | #1 |
'70 c10 column shift question
1970 c10 just finished a full restoration and working through the minor issues.
One of which is: Isn't the column shift supposed to lock into park. By that I mean Shouldn't you have to pull the shift handle inward then shift into drive. Currently I can just pull the shifter right out of park Any info appreciated. Mark
My build page http://67-72chevytrucks.com/vboard/s...d.php?t=764662 My cabinet building site http://www.cbcabinets.com |
06-24-2017, 06:52 PM | #2 |
Re: '70 c10 column shift question
make sure the shift handle inside is lubed and replace the shift bushing at the bottom of the column , then if needed adjust the linkage so it lines up with the "detent" on the bottom of the column . it's a PIA with disc brake master in the way .
06-24-2017, 07:57 PM | #3 |
Thanks. Linkage is adjust and all of that works good.
Isn't there a Saftey mechanism in place so the shifter cannot be accident bumped and put into reverse? Pretty sure there is. The shifter itself pivots in slightly inward where is shifter rod meets the column. So you should have to pull the shifter toward you a bit before being able to shift out of park. In my case that feature isn't working. Just wondering if anyone has repaired this feature and may have some insight. Posted via Mobile Device |
06-24-2017, 09:00 PM | #4 |
No safety mechanisms, newer vehicles are spoiling you. If it's all adjusted correctly, then that's as good as you'll get. You can weld and file the notch in order to need a more solid forward pull on the shift lever if you were inclined.
If you're dissatisfied still you'll have to get a new Ididit, Flaming River, etc column with keys so the wheel and shifter will lock out. |
06-24-2017, 09:17 PM | #5 | |
06-24-2017, 09:20 PM | #6 | |
Ok. But why does the shift pull forward then? It spring pivots. No it's not tilt steering though.
I'll take a pic of it tomorrow. I have 5 year old twins and I don't normally leave it running in park often but thought I would fix it for peace of mind if it was an option. One thing to had is the steering column was replaced from a 1972 c10 donor truck by PO Quote:
06-24-2017, 11:47 PM | #7 | |
The Older Generation
I wouldn't call it a safety mechanism but there is a detent on the lower shifter arm that is supposed to keep the shifter from moving out of park until you pull it back toward you. Your shift tube may be gummed up keeping it from moving up and down..... Below are a couple of pictures that show the detent. In the second picture (actually both pictures) there is not supposed to be a gap between the two parts, they should be tight together. Try this: Spray some PB Blaster, Liquid Wrench, or something similar (not WD-40) into the steering column, where the shift lever goes in. Don't be afraid to give it a good dousing. After you spray it pull the shift lever up toward you and push it back down toward the dash. It should move up and down a couple of inches. Do this 4 or 5 times. This will help free up any sticking in the shift lever tube. The reason the shift lever moves up and down is because it should be pulled back towards you to shift it into and out of the park position. LockDoc
06-24-2017, 09:29 PM | #8 |
You can acually look at the bottom of the column and see whats happening from the engine bay. Have someone shift the truck out of park and you'll visibly see the only small safety feature on the gated portion of the column, which is the notch that you clear by pulling the shifter forward. After 45+ years of being shifted the metal has most likely rounded off making the shifter easier to slip out of park, rather than having to pull the shifter forward and pull down. That is why I said you could weld it back up, and square it off. However, the effort between a factory new column, and a worn column isn't a significant difference.
06-24-2017, 11:00 PM | #9 |
http://67-72chevytrucks.com/vboard/s...d.php?t=491049
hope this gets you there....very comprehensive about your problem |
06-25-2017, 12:09 AM | #10 | |
Leftybass
You were right on the money. It absolutely is a safety feature GM developed to keep a running truck/car from accidently being bumped into reverse or child pulling on the shifter. It was worn down just as you thought. I just drilled a hole and put in a 10-24 pan head and nut and works perfectly. I was expecting it to be internal in the column. Simple fix. I'm one of the guys who wants all aspects of my restoration to work as it did from the factory. Thanks for the info. That's why this is such a great forum. RRM Quote:
06-25-2017, 12:15 AM | #11 | |
06-25-2017, 11:22 AM | #12 |
Any possibility of a pix "StoneyCreek"? I may have to fix mine sooner than later.
TKX from a fellow Buckeye.... |
07-02-2017, 10:27 PM | #13 |
Here's a pic by request of the 10-24 machine bolt and nut fix for the worn detent
First pic is in park 2nd pic was in drive
07-02-2017, 10:29 PM | #14 |
Pics!
So hard on a phone sometimes. I did use a stainless bolt so it wouldn't wear as quick Mark
