06-27-2017, 10:05 PM | #1 |
Late model brake booster install?
My doner truck (2005 Silverado) has a really nice looking brake booster / master cylinder on it, anyone know if this will install on my '68 without issues? Now that I'm thinking about it, I believe the lines are bigger on the '05, that would be a problem.
06-29-2017, 06:38 PM | #2 |
Fabricate till you "puke"
Re: Late model brake booster install?
The nuts on the lines, will also be metric thread on the 05....IIRC. Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
06-29-2017, 11:16 PM | #3 |
I had the same issue with a Hydroboost with a metric M/C I just used some pre made short brake lines with the right flare nut on the lines that fit the M/C and cut the other end off and 3/16 nut and double flair for the Pro Valve, worked for me!
06-29-2017, 11:31 PM | #4 |
60-66 Nut
You might find this helpful to achieve a correct and safe installation.
http://www.67-72chevytrucks.com/vboa...d.php?t=347484
