Old 06-28-2017, 07:48 PM   #1
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
One Ton Suspension Upgrades
I just picked up a 72 Motor Home. Will the crossmember from a 85 one ton bolt up in place of the stock one? I want to change the drivetrain to something that has parts available. Looked at a few sights and no one has rear drums for a dually. Did some searching here and everything that comes up with changing to 4wd from 2wd which is not what I am trying to do.
Thoughts?
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 07-03-2017, 03:01 PM   #2
Clyde65
Clyde65's Avatar
Re: One Ton Suspension Upgrades
Yes they will swap. 73-90 1ton
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 07-03-2017, 05:04 PM   #3
69gmcc10
69gmcc10's Avatar
It will bolt right up without any issues except one hole,the front lower bolt hole on the side of the frame is off just a little. I used a dremel to wollow out the bolt hole so it would line up... don't pay any attention to the gouges on the frame where the dremel went rogue.
69 GMC C10 build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=501676
03 Silverado build thread-http://67-72chevytrucks.com/vboard/s...d.php?t=591582
69gmcc10 is offline   Reply With Quote
Old 07-04-2017, 12:09 AM   #4
71meangreenc10
Thanks guys,
Picked up a complete front and rear assemblies. Got to see what the gearing is on the 14 bolt.
Great pick 69gmcc10.
Smitty
71 C30 Wrecker
Old 07-07-2017, 10:30 PM   #5
Whitey__62
Couple options as well. You can keep the original front crossmember and run a set of PBFAB control arms, they can be made with 73-91 balljoints, 1" forward and 1" in to allow for better wheel alignment in wheel well and wider wheel/tire. Then you have more brake options too. You can run drop spindles for 73-91 at that point as well.
I'm going to run this with a higher GVW brake spindles from a 84 1ton dually, trying to keep the true 1ton brakes. I'm swapping in a 4.10 14bff and making it disc brakes as well. Might switch to a 3.73 to make the sm465 a little better for top end highway driving.
Whitey__62 is offline   Reply With Quote
Old 07-10-2017, 01:12 AM   #6
71meangreenc10
What Disk Brake Option are you looking at?
Smitty
71 C30 Wrecker
Old 07-13-2017, 03:08 AM   #7
Whitey__62
Smitty
I'll be running the single wheel 13x3.5" brakes from a 84 Crew Cab 2wd. Additionally I'll be doing a crossmember swap with drop spindles.
