C10 won't idle
So I have a 68 c10 with a 250 I6. It ran fine for 125 miles then it started buckin and stealing doin down the road. So I cleaned all the lines, replaced the fuel pump, cleaned the carb, and cleaned out the tank. It ran like a sewing machine the rest of the day. I woke up the next day and it hard started which had never happened. Then it wouldn't idle unless I gave it gas. I drove it another 25-30 miles until it go to where it would die without gas and it was missing terribly and really hard starting. So I replaced the gas tank and just got a new carb, new plug wires, new plugs, new dist cap, new rotor, new coil, new points, set the gap to .19 and set the timing to 8 degrees BTDC. I replaced the carb yesterday and adjusted it to where it now idles for 30 seconds but the rpm rises really high randomly and it dies. I'm stumped. Any help would be appreciated
Re: C10 won't idle
Why does the RPM raise up randomly? That'd be the first thing I'd chase. Might be as easy as a vacuum leak, and if you're running rich, introducing extra air speeds up the engine.
You could wait until it does the high idle again and spray carb cleaner around the carb base gasket to see if it changes anything. If there's a leak it'll suck in the spray and run "different", but if there's no leak it'll change nothing.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
#3 | |
Re: C10 won't idle
72 Chevy C10 383/465 69 Corvette convertible 454/650 |
Re: C10 won't idle
Ok guys thanks I'll try it out. I forgot to mention that I put a rag on it and it ran really good but as soon as I took it off the rpms surge and it dies
#5 | |
Re: C10 won't idle
Re: C10 won't idle
So I did like y'all said and the rpms didn't raise up when I sprayed the carb. I sprayed all around it except in the top. All around the gaskets and such. I did notice that the truck idles a bit longer when I run the vac advanced to the front inlet instead of the side one or if they're Both plugged. But the problem still persists. Really high idle, hard starting, and missing. I believe it isn't firing right on all cylinders. I took the dist cap off and I did notice that there was a black smudge on the #1. Other than that all cylinders showed equal signs of spark
Re: C10 won't idle
Ok thanks grumpy. It just started pouring but When it stops I'll try it out. I hope it will fix it
Re: C10 won't idle
almost sounds like a timing issue....just a thought
Re: C10 won't idle
Thanks. . Sure makes sense. I would appreciate a picture. Having trouble visualizing it for some reason.
Re: C10 won't idle
Quick question grumpy. How do I change the PCV valve? Do I have to take the intake off? And are u sure it's a PCV valve or a egr
![]() Join Date: Dec 2013
Re: C10 won't idle
Re: C10 won't idle
Ok I will. And my pcv valve is fine. I need to know about the fitting that the hose runs to from the PCV to on the intake
Re: C10 won't idle
Man I'm new to the forums and i can't figure out how to send a pic out of my photo gallery. I'm on a iPhone 5s
#15 |
Re: C10 won't idle
I have a monojet. And I want to know about the fitting to the left of the carb. It is completely clogged with crud. Where does it go to? And how do u get it off to replace it? And do I have to take the intake off?
#16 |
Re: C10 won't idle
you don't replace it you clean it out . its pressed into the manifold . Look thru my parts thread you'll see a broken one and what it looks like inside the intake manifold ' Clean it out using carb cleaner and a wire coat hanger you won't hurt anything .
![]() http://67-72chevytrucks.com/vboard/s...d.php?t=737893 post # 32on the second page |
#17 |
Re: C10 won't idle
Ok thanks grumpy i appreciate it. The tube just ends inside the intake so all I would have to do is just push it through and burn it out right?
#18 |
Re: C10 won't idle
#19 |
Re: C10 won't idle
When an engine is cold, it just means not yet close to operating temp. Not necessarily that it is 40 outside. Until the engine starts warming up, it requires a much richer mixture.on .
BTW.. are you far from Keesler. Spent a couple months there back in 76 for TAD.
#20 |
Re: C10 won't idle
No not at all. I'm about 15 miles from it @grumpy
#21 |
Re: C10 won't idle
Ok guys I did like y'all said and sprayed for vacuum leaks on the intake and there was one by the fitting where the pcv hose runs. The intake has a small gap. I'm gonna tighten it up
#22 |
Re: C10 won't idle
Glad it is running better. Hope you and your Dad enjoy driving it.
