10-23-2003, 10:02 PM | #1 |
Fram Oil Filter
Which Fram oil filter works with the 350? Is it the Ph5, or Ph 13?
I know dumb question, but I heard that they don't make one of the 2 oil filters anymore. Thanks
Nelson 1970 C10 350 Auto. A/C not Working |
10-23-2003, 10:08 PM | #2 |
Cant help with the fram but know that the ac delco is a PF35
1968 SWB CST |
10-23-2003, 10:12 PM | #3 |
I use the ph13 in my 350
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
10-23-2003, 11:29 PM | #4 |
Cantankerous Geezer
I quit using Fram filters after reading this. Switched to Wix.
http://minimopar.net/oilfilterstudy.html http://minimopar.net/oilfilters.html
Fred There is no such thing as too much cam...just not enough engine. |
10-23-2003, 11:42 PM | #5 |
Formerly yellow72custom
I don't use Fram filters either...i have cut one open and they don't have alot of material on the inside.
I use a Wix 51061 for my 350 (has an anti drainback valve too). Costs about $5.50 but is worth every penny IMO
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
10-23-2003, 11:50 PM | #6 |
its all about the +6 inches
I always used PH13, untill i too cut one up. I use NAPA filters, but that's becouse I get them free at work. (they are made by WIX)
10-23-2003, 11:58 PM | #7 |
Sisyphus was my mentor!
use a wix man - i saw a cut-away of a bunch of fliters & wix was the best - thicker metal & better guts. They're more coin but thats all I use.
passthebuck #5642 -TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4. -a 2013 Honda Civic as my "sensible" car |
10-24-2003, 12:15 AM | #8 |
FRAM
I used Fram for years. They used to be good. Now all they have in mind is corporate profits & make them as cheap as possible. I've also switched to NAPA......Zoomy
10-24-2003, 12:21 AM | #9 |
Wix, Hastings, Napa are about the only good filters on the market. Fram is like on the bottom with AC Delco one step up from that. Its called you get what you pay for. Fram $2.49 at Wallmart or you can pay $5 or $6 for a real filter. Kinda reminds me of when I bought a helmet for my Polaris. The guys said you buy a $20 helmet if you have a $20 head. the same goes for filters. Its protecting the life of the motor. All I can add is DON"T use Valvoilne Maxlife! Just my 4.5 cents worth.
10-24-2003, 12:22 AM | #10 |
WOW!!! With this new info I will definately be switching to a Wix filter. Thanks for setting me on the right path!!! Funny how this thread changed from a 'which part number' to a you need to change to a different filter. Thanks again for the great info!!!
Shawn
10-24-2003, 04:13 AM | #11 |
If you use NAPA filters only use the gold. They are rated real well (flow versus filtration). K & N are the tops and Mobile 1 is a good filter also.
'68 Short Step LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc |
10-24-2003, 04:36 AM | #12 |
Yeh It's Fast
PF35
I always use the ac delco PF35 works fine for me
(I'm sorry if the spelling isn't correct,i'm trying the best I can ) 1972 C20 3/4 Pickup Fleetside 502ci Th400 Click here to view pictures of my truck 1971 C20 3/4 Pickup Fleetside 350ci 3speed manual gearbox "IF IT AIN'T BROKE DON'T TRY TO FIX IT" Zwijndrecht, The Netherlands Europe |
10-24-2003, 10:04 AM | #13 |
By the way they don't make the PH 13 anymore it's now PH 5.
1980 Chevy Shortbed Pickup 1969 Z28 engine Turbo 350 |
10-24-2003, 11:11 AM | #14 |
Yep, Fram are junk. They spend more on advertising than anyone else and then end up with the worst filter on the market.
WIX,Mobil 1,NAPA,Purolator and K&N are about the only way to go.
1968 Chevy C10 Short Fleetside/Wood floor ECE 4-6 Drop / 406 Small Block 1971 Chevelle 427 Big Block |
10-24-2003, 11:21 AM | #15 |
I just bought a PH13 2 weeks ago? when did they quit making them? Not that I really care since I won't be using them again
10-24-2003, 05:35 PM | #16 |
Senior Moment
Thge local Kragens has PH13, I just bought one. Thinking on taking it back now
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
10-24-2003, 07:10 PM | #17 |
there are only 3 manufacturers that make oil filters one is fram the other hastings and the other purolator other then that one of those 3 companies make them. i use purolators myself
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
10-24-2003, 07:22 PM | #18 |
I have been using Mobil1 oil filters. I agree you get what ya pay for. I don't skimp on oil filters or air filters or oil breathers.
1969 Chevy C10. Dakota Digital Gauges, 383 Votex Engine, MSD 8361 Distributor, MSD 6A Unit, Demon Carb, Phoenix Transmission 4L80E trans, 3:73 Posi Rear End Early Classics 6 Lug Disc Brakes and Spindles All Stainless Lines |
10-24-2003, 08:17 PM | #19 |
i use the napa golds also. i think the part number is 1061. but if you give them the fram part number you use they can cross referance it for you.
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works '05 1500 Crew Cab RIP '84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker '80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's |
10-24-2003, 08:48 PM | #20 |
I use a bypass and a Fram filter. After reading these posts,
I believe I will switch from the Fram. EdB |
10-24-2003, 09:10 PM | #21 |
Designated A-hole!
Since I joined the board I have quit using Fram myself. Just another gold nugget of knowledge gained here!
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
10-24-2003, 09:24 PM | #22 | |
Honeywell (merged with Allied Signal and owns Bendix and others) makes Fram, Deutch, Luberfiner, Toyota OEM and did make Quaker State (for many years). Avin Meritor makes Purolator Premium Plus, PureOne, Ford OEM, V1, and now Quaker State among others. DANA makes filters for WIX and makes the NAPA Gold (NAPA Silver filters are made buy cheapest bidder and manufacturer has varied so stay away from these--see my post above). Clarcor owns Baldwin and Hastings and also makes Amsoil's filters. Champion Labs makes Mobil 1, K & N, Supetech, Bosch Premium, STP, Ultra Guard Gold, and AC Delco Duraguard. Keep in mind even if different brands are made in the same factory by the same company, quality is different between them as Champion Labs shows having some of the best and some not. Additionally DANA makes MOPAR/Autopar, AC Delco and Ford For Canada. Confused yet?
10-24-2003, 10:22 PM | #23 |
I also remember as a kid the old Kralinator Filter factory that was a few blocks away from where I lived. It's now Dana!
10-24-2003, 10:42 PM | #24 |
I have never unscrewed a Delco PF-35 off an engine because the filter failed. Just like I have never seen a round or worn out Firestone tire as the belts always break before they wear out, but that is another hot topic we can save for a thread all its own!
Kevin Korff Evansville, IN 47711 1997 Silverado 3500 LWB Vortec 454, headers 4.11 posi. Victory Red WOW! 1976 Oldsmobile 98 Regency four door 42,000 miles original paint. This is still a car! 1990 Oldsmobile 98 Touring Sedan 34,000 miles 1983 Hurst/Olds 30,000 actual miles 2013 Ford Taurus SHO 1972 Hurst/Olds-a work with no progress 1972 Oldsmobile 442 Convertible 455 |
10-25-2003, 12:08 AM | #25 | |
OK off my soap box now.
