07-04-2017, 03:54 PM | #1 |
Hatch hinge grommet help
I have a 71 k5. I removed the hatch to replace the gasket around the entire outside edge. I also removed the grommets at the hinges both on the hatch and roof side. I have purchased new grommets from several different vendors. They look correct for the hatch side but not the roof side. Does anyone manufacture the roof side grommet? I am saying grommet because they are the style that push into a hole not the one with 2 screws. Any help will be welcome
07-04-2017, 04:06 PM | #2 |
Carpe manana
Re: Hatch hinge grommet help
Any pics of new and old gaskets/grommets? There are two styles of the hatch side grommets/gaskets. I thought the top side gaskets were all the same and similar to one of the two hatch styles. Pic shows the differing hatch styles.
07-04-2017, 04:32 PM | #3 |
The black ones are new and the white ones are off the top side of the hinges. There is a narrow and wide side if I put the narrow side up the bevel on the inside is going in the wrong direction if I put the narrow side down it will not fit. As u can see the old ones also have an extra boss not sure if that matters?
07-04-2017, 04:48 PM | #4 |
I didn't forget about you I just ordered another parts manual off ebay for 38-69 was hoping it would be in there. I missed it the first time and he just relisted it should be here by the end of the week. Keep your fingers crossed LOL.
07-04-2017, 04:58 PM | #5 |
Thanks Dwayne still trying to sort it out
07-06-2017, 09:54 PM | #6 |
Bad news the catalog has no illustrations and I don't have a clue where to look. To top it off I don't see any blazer info just suburban and truck sorry.
07-07-2017, 04:37 PM | #7 |
Thanks again Dwayne I am surprised nobody else has had this issue
07-09-2017, 07:59 PM | #8 |
Update: I installed the new grommets with the wide side up. They fit fine and the hinges slide in with a lot of dish soap. Everything is good, I guess I was over thinking it thanks for all the input.
07-09-2017, 11:21 PM | #9 |
Carpe manana
Good to know thanks for the update. I'm curious if the style that makes use of the retainer and two screws is reproduced: I have a single wall top here that has this style on both the hatch and top sides and a double wall that used the two screw style on at least the top side.
07-15-2017, 08:46 AM | #10 |
Deadheadmn they do reproduce the rubber with the 2 screw holes I bought a set of rubber that I can send u if u want them I have no use for them PM me your mailing address and I will send them to you.
07-15-2017, 09:35 AM | #11 |
Carpe manana
Thanks!! I appreciate the offer. PM sent. Pete
