07-05-2017, 08:08 PM | #1 |
New looking for help
Hello, I've been looking for a C10 for a while that I can work on with my boys as they get older. I found a 72 C10 SWB for $2500. They guy said the ID in the glove box doesn't match the original VIN. How big of a deal is this? I'd like to eventually tear the whole thing down to the frame and build it from the ground up. Now the guy doesn't want to share the VIN for some reason. Should I be worried? It's a 4 hour drive to even check it out. I can post pics of that would help. Just looking to see if I'm being taken or not. Any advice would be appreciated.
07-05-2017, 08:17 PM | #2 |
Re: New looking for help
He did share the first 6 of the VIN. Matches the description he gave me so far. CS142B
07-05-2017, 08:57 PM | #3 |
07-05-2017, 09:04 PM | #4 |
Unless you see the rosette rivets, I'd walk away. But I'd probably walk away anyway. There are projects just as nice for that price - not worth the hassle to deal with a hesitant seller and a mixed VIN soup. To register it, I'd remove the glove box door beforehand personally to avoid confusion.
07-05-2017, 09:09 PM | #5 | |
07-05-2017, 10:07 PM | #6 |
Sorry. There's no guarantee it's a swb truck - could be shortened frame or a cab swap onto a swb frame, shortened bed, added real swb bed to a shortened frame, who knows. I'm not at home or I'd crosscheck the gvwr for a swb c10 - don't recall if it's the same as the lwb. I don't see any other way to verify it was originally a swb truck without a SPID unless you inspect it.
07-06-2017, 12:19 AM | #7 |
Is it just me or does it appear that none of the body lines match up and the panels are all tweaked up?
07-06-2017, 02:22 AM | #8 |
In photo 3, I swear that I can see a faint vertical line in the area where a long wheel base would be cut to shorten(?).
Also, in that last photo, the rear wheel looks to be too far forward in the wheel opening(?). There is a LOT of filler behind the passenger side bed panel too. I'm not bashing the truck, just making observations. POP
2016 RAM Laramie HEMI 1966 Fairlane GT/A, 390/335 HP If it costs you a dollar to make a friend, KEEP THE DOLLAR. If it costs you a friend to make a dollar, KEEP THE FRIEND. |
07-06-2017, 08:35 AM | #9 | |
07-06-2017, 08:43 AM | #10 | |
07-06-2017, 11:20 AM | #11 |
I agree with most of the other comments.
My observations relate to the pic of the full side of the trick, 3 things standout 1) The paint forward of the rear wheel well looks new and in great shape ...possibly signs of the 'shortening' process?..where it would be cut/welded/filled and repainted, etc. 2) The wheel well looks likes its about 1"-2" too far back relative to the wheel centreline. 3) Its a leaf spring truck...instead of a trailing arm coil spring. Nothing wrong with this but these might have been easier to shorten than the trailing arm style? ...experts can weigh in on that. So: Ask the seller if this truck was shortened/modified down from a long wheel base truck?...and if he isn't sure....then prompt him to take 15-20 seconds and check the frame for patches and the strapping plates or post a couple of quick pics of it under there for you. If he isn't up to this....then he isn't a seller to deal with. Move on and be patient there are a lot more trucks out there. All Good Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL 1966 Chevy 1/2 ton (Florida- Red/white) 1972 Chevy 1/2 ton (California- Blue/white) 2005 Chevy Silverado HD2500/Duramax 2000 Dodge Ram 1500 |
07-06-2017, 11:32 AM | #12 | |
07-06-2017, 12:09 PM | #13 |
Without seeing it in person it's hard too tell.
I don't believe the bed was cut as there is no indication of any stake pockets or welds inside the bed. Most times the rear wheels always look too far forward but this one seems "off" just by the pic. It could also be the angle of the pics but the cab-bed gap looks off too. But if someone put the bed on a short end frame then why didn't they try too push the front panel back better than it is. One thing is for sure that driver side rocker looks way off. I would certainly check the driver and passenger side inner cowl for rust as some is evident on the firewall. I'm curious as too why the power booster isn't hooked up. The fenders definitely weren't lined up. This could be a good deal for a swb but a good look around it would really tell the story.
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
07-06-2017, 03:09 PM | #14 | |
More pictures added to this album. https://imgur.com/a/52xtb Looks like the frame hasn't been cut to me. The rivets look good too...I'll head down Saturday AM and check it out in person. Anything else I should look at? If I pick it up, I'll have to get a build thread going along with some ideas on where to even start! lol I can't thank you all enough for your help though. Last edited by 98sonoma; 07-06-2017 at 03:15 PM. |
07-06-2017, 03:32 PM | #15 | ||
"I ain't nobody, dork."
Any seller that won't be up front with anything when it comes to numbers should be avoided at all costs. There is a reason why they are being shady as hell.
The alternator is on the wrong side so the engine is either a later model transplant with a long water pump, or it could be a later model frame and engine combo. When someone won't divulge numbers it means you're about to get a crap deal. Gary
07-06-2017, 03:47 PM | #16 | |
What I did see of the VIN said it was a 6 cylinder truck originally, so the 350 is definitely not original. Guy claims he is asking for what he paid for it because he has medical bills. I did get a video of the engine running. I couldn't detect any odd sounds from it while it was running. |
07-06-2017, 03:48 PM | #17 |
I'm not really thrilled about the vodka bottle or whatever it is under the hood, lol.
07-06-2017, 03:52 PM | #18 | ||
Tell him to send you a pic of the frame under the cab and also a pic of the VIN stamped on the frame.
Gary
07-06-2017, 04:00 PM | #19 |
07-06-2017, 04:19 PM | #20 |
My 2 cents .... it gets to a point where it is what it is ... esp at that price and it's running ..... looking for a good father son project ... there u go .. plenty to do there ..... few things that are good to know like if bed was cut down ... if it was it's not that big of a deal ... so long as u know . Is frame straight ? ..... hopefully vin number matching title works out .
M.A.G.A. |
07-06-2017, 04:24 PM | #21 | |
07-07-2017, 06:32 AM | #22 | |
07-07-2017, 07:26 AM | #23 |
I don't know about you , but I tend to look at project trucks as a sum of all the parts. You have no tailgate so you have a bed that would run you at least 500 to buy, as well as an org short disc brake frame . 800-1000. Dog house for a 72 is at least 400, and then a titled cab, [assuming the title is ok], another 650-750. Add the accessories you would need and no telling what else IE eng, tranny, seat, gas tank,easily another 2-3000. So yes, if the title is good, I would buy it, as long as there was not a problem with the frame or another costly component.
07-07-2017, 09:38 AM | #24 | |||
Gary
07-07-2017, 11:09 AM | #25 |
