Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Welcome and Discussion > General Discussion
Old 07-09-2017, 08:09 PM   #1
Paul Dixon
1971 chevy truck
I have changed the wiring on this truck with OEM harness. It has a one wire alternator which I eliminated regulator. I connected the center two wires, (red and white) as well as the (blue and brown wires) thus completing the loop. The problem I'm having is every time I turn the right turn signal on the hi beam indicator flashes with the turn signal flasher but not on instrument cluster, the left turn signal operates correctly. If I turn headlights on hi beam the rt. turn signal light on dash lights continuously even though it works correctly. The green wire is in correct place off head light switch which operates cluster lights but they don't work either. I have changed the printed circuit in hopes of resolve with no change. All grounds are complete and have added tach with no problem. Some one tell me what I'm missing. Paul
Paul Dixon is offline   Reply With Quote
Old 07-09-2017, 08:44 PM   #2
notsolo
notsolo's Avatar
Re: 1971 chevy truck
Hey Paul, Start with the ground wires, dash cluster, radiator support, engine and cab. etc. Might just be bad ground.
notsolo is offline   Reply With Quote
Old 07-12-2017, 06:42 PM   #3
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
2nd that on the ground checkin'
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
