Old 07-12-2017, 02:23 AM   #1
ApacheIvan
ApacheIvan's Avatar
Strange AC problem?
Is my alternator bad? When I turn on my AC my alternator sounds like it is going out. sounds like the bearings in the alternator starts squealing, it is fairly new, the belt is tight, turn the AC off and all is great. I thought it was a belt at first, but it is coming from the alternator for sure.. anyone else have that happen?
Dale - ApacheIvan
1972 Chevy Custom/20 Custom Camper Highlander
http://67-72chevytrucks.com/vboard/s...d.php?t=740479
Original Owner
** Do you have a 1972 Plaid Pickup?**
ApacheIvan is offline   Reply With Quote
Old 07-12-2017, 09:49 AM   #2
truckster
truckster's Avatar
Re: Strange AC problem?
AC does increase the electrical load. That's the only connection I can think of.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 07-12-2017, 10:00 AM   #3
Andy4639
Old member
Andy4639's Avatar
Talking Re: Strange AC problem?
How do you have the belts routed? Is this the old v-belts are serpintine belt.
The compressor electrical out put will not make the alternator bearing go out and if it runs ok with the ac off then its in the compressor side.
I would find it hard to be the alternator on what you have posted.
The only thing I can think is one of the components isn't lined up good and putting stress on the alternator pulley.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 07-12-2017, 11:24 AM   #4
ApacheIvan
ApacheIvan's Avatar
It is the stock configuration, stock type belts. I will do a bit more investigation today with a stethoscope and see if I can pin it down. All the alignment looks fine. It sure sounds like the alternator side.
Dale - ApacheIvan
Original Owner
Old 07-12-2017, 11:57 AM   #5
ApacheIvan
ApacheIvan's Avatar
Ok, so I guess I should not assume I am having the same issue twice. Just popped the hood and turned on the AC at idle and I can see the clutch hesitating at times, meaning it looks like I have a strobe light on it.. it is either failing or needs freon or oil.. I am not really savvy on the internal working of an A6 compressor, I don't want to throw away money trying to figure out if I need to replace the compressor, they are expensive enough.
Suggestions?
Dale - ApacheIvan
Original Owner
Old 07-12-2017, 12:17 PM   #6
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Originally Posted by ApacheIvan View Post
..... turned on the AC at idle and I can see the clutch hesitating at times, meaning it looks like I have a strobe light on it.. it is either failing or needs freon or oil..
Subscribed... my new compressor also occasionally cycles on-off-on rapidly, the shop said the system is full....??
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 07-12-2017, 10:34 AM   #7
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Mine is making sounds similar to what you describe, but my stethoscope says the noise is coming from the compressor.
My alternator, water pump, and PS pump all sound normal.
Just bought the compressor at NAPA.... and it was made in China.
- Mike -
RIP El Jay
Old 07-12-2017, 11:32 PM   #8
dmjlambert
dmjlambert's Avatar
I learned the hard way that if you get a Duralast belt from Autozone or other house brand from auto parts stores, they are not adequate. They stretch and don't hold tight enough to the pully. You must get a Gates brand belt. When you get one you will immediately see the difference. Autozone probably has Gates, I know O'Reilly does.
Old 07-13-2017, 12:57 AM   #9
ApacheIvan
ApacheIvan's Avatar
That is what I am going to do in the morning. I think that is what it happening. I have the belt so tight it has stretched and actually gotten narrower.
Dale - ApacheIvan
Original Owner
Old 07-13-2017, 01:38 AM   #10
leddzepp
Moderator
leddzepp's Avatar
Does the AC work? (When the belt isn't squealing anyways). How hot was it outside?
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 07-13-2017, 01:49 AM   #11
ApacheIvan
ApacheIvan's Avatar
Yes everything works, all brand new. I do have to take the POA back out and adjust the pressure for r134 but other than that yes..
And it is in the upper 90s
Dale - ApacheIvan
Original Owner
Old 07-13-2017, 12:38 PM   #12
jeffahart
jeffahart's Avatar
I am running a gates 7555 for the A/C and fan. It squealed a bit at first but after running it a bit I cinched it down again after it settled in . No more pig squeals.
White K20
jeffahart is offline   Reply With Quote
Old 07-13-2017, 01:02 PM   #13
ApacheIvan
ApacheIvan's Avatar
I just ordered my Gates 7555. Will get it tomorrow.. we will see
Dale - ApacheIvan
Original Owner
Old 07-13-2017, 04:26 PM   #14
cleszkie
cleszkie's Avatar
If all else fails, you can take some emory cloth to the pulley grooves to give them some "bite", and to remove any old burnished belt material. I do not recommend using any sort of "belt conditioner" or "belt dressing" to increase belt grip on the pulleys. That stuff just makes a mess, and can make the problem worse in some cases.
X2 on the Gates belts.
cleszkie is offline   Reply With Quote
Old 07-13-2017, 04:23 PM   #15
dmjlambert
dmjlambert's Avatar
What is your opinion of belt and hose dressing? I've seen cans and pouches of it at the store and wondered about it. Good? Bad? Waste of time and money or good stuff?
Old 07-13-2017, 05:42 PM   #16
Stocker
20' Daredevil (Ret)
Stocker's Avatar
I agree with cleszkie, I tried belt dressing a long time ago and it made a mess and fixed nothing. Never again.
I have used a bar of soap to chase a squealing belt, but then I adjust it or replace it as necessary. The belt, not the soap....
- Mike -
RIP El Jay
Old 07-17-2017, 06:36 PM   #17
ApacheIvan
ApacheIvan's Avatar
Gates 7555 came today, on the truck already, night and day! No more slipping, you can just tell that there is more weight and girth to the belt. Thanks for the recommendation!
Dale - ApacheIvan
Original Owner
Old 07-17-2017, 07:27 PM   #18
jeffahart
jeffahart's Avatar
I keep a 7355 power steering, 7525 Alternator and the 7555 AC belts hanging from my ceiling for spares. Along with the upper 20607 and the lower 20694 Rad hoses. Because.... that's the way we've always done it around here!
White K20
Old 07-21-2017, 11:23 PM   #19
ApacheIvan
ApacheIvan's Avatar
The Gates 7555 belt made all the difference in the world. No more stretching, no more squealing, looks and works great!
Dale - ApacheIvan
Original Owner
