Old 10-24-2003, 05:57 PM   #1
Lynx
Lynx's Avatar
Power steering pressure hose
Ok here is the deal it has been leaking for quite a while now so i finnaly decided to replace it. I got the new hose and it has to be the most straight forward thing to do. BUT I cant get the freaking old one off!! The bolt on the resovior will not move at all, I even got underneeth and put all my weight into it and i cant move it at all... whats the deal???
and the one on the pump itself i cant find a wrench to fit it? its not 3/4 and its not 11/16 is it metric or somthing wierd? i donno i can work on that one cause its the same size as the new one i got and i can keep looking for the right wrench!
Ben
1983 Silverado SWB 305
2002 Silverado Extended Cab 5.3
http://members.shaw.ca/bkennett
Lynx is offline   Reply With Quote
Old 10-24-2003, 06:35 PM   #2
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
I think it is metric. If you don't have one get a crescent wrench on it and get it off. Try some WD-40 or Liquid Wrench on it to loosen it up.
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 10-24-2003, 06:54 PM   #3
TwinTurbo
TwinTurbo's Avatar
Saw off the tube so you can put a socket over it, makes it much easier to remove.
TwinTurbo is offline   Reply With Quote
Old 10-24-2003, 07:13 PM   #4
79BIG10
79BIG10's Avatar
I wouldn't do that. Some saw shavings could get in there and cause trouble for the steering box. If you want to cut it use a pipe cutter. Much faster and less mess.
Old 10-24-2003, 07:39 PM   #5
76HighSierra
DAMN, I love Big Blocks!
76HighSierra's Avatar
If the pump is full of fluid, I wouldn't so much worry about shavings, as the outflow of fluid will take the shavings with it, but yes, it's a good idea to use a tubing cutter.
Marc Bona
Hobbs, New Mexico
1976 1/2 ton GMC High Sierra.
454 c.i.d./ TH400. *Soon to get a mild warming over.*
3.40 rear.
76HighSierra is offline   Reply With Quote
Old 10-24-2003, 07:50 PM   #6
Jason Spears
Jason Spears's Avatar
One of the nuts is metric. I just replaced my pressure and return hoses a few months ago. I can't quite remember but I think it was an 18 mm. Luckily, mine were not stuck. I did end up twisting off the metal tube coming off the power steering box. Had to make up a new one.
Sometimes if I tap on a wrench with a hammer the impact will be enough to unstick the nut. Good luck.
Jason Spears is offline   Reply With Quote
Old 10-25-2003, 11:53 AM   #7
crackajacka
Stylin
crackajacka's Avatar
yea there metric and a real B***H, just like every other fitting that gm doesnt want u to take off and replace yourself
Ive been traveling for some time, with my fishin pole and my bottle of shyne.
Most Girls like finished products and just dont understand what a good addiction does for you
http://www.paulwall.us/
crackajacka is offline   Reply With Quote
Old 10-25-2003, 09:55 PM   #8
soleeagle
soleeagle's Avatar
Try to use some Blaster PB, I used it on mine and it help with the removal.
Chuck
'85 Chevy Silverado 4X4
'91 Chevy 4X4 Suburban
http://www.cardomain.com/memberpage/545941
soleeagle is offline   Reply With Quote
