Old 07-13-2017, 10:36 PM   #1
Techx
Previously gear vendors th350
I get kinda lazy sometimes especially on things I don't know a lot about. Instead of rebuilding my th350 I am thinking of buying a new one ready to go. I was also wanting to add the gear vendors over drive system. Does anyone know of a complete setup ready to roll.
Techx is offline   Reply With Quote
Old 07-13-2017, 10:44 PM   #2
kwmech
Re: Previously gear vendors th350
The majority of what I see is the Gear Vendors on the back of T400s. Probably have to have it all built, unless you can find something on Craigslsit
Old 07-14-2017, 12:20 AM   #3
gator2511
gator2511's Avatar
I put a TH400 in my 72 then installed a GV unit. Had to pull the transfer case and have the input bearing hole bored to fit the larger bearing and shaft on the TH400. Also needed an adapter for the tranny and had to shorten the rear drive shaft. Even if You don't change the 350 out I don't think you will find one that will install without some work.
gator2511 is offline   Reply With Quote
Old 07-14-2017, 07:10 AM   #4
Shaky
Six in a row makes it go...
Shaky's Avatar
You could go to the gear vendors website and look at the TH350 kits:
http://www.gearvendors.com/ag3s.html
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
Old 07-14-2017, 07:17 AM   #5
GR8-68
GR8-68's Avatar
Heck by the time you pay 3 grand for that you might as well convert to a 4l60 or 80.
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline   Reply With Quote
Old 07-14-2017, 07:44 AM   #6
dennislbrooks
dennislbrooks's Avatar
Agree with GR8. Unless you are drag racing or maybe pulling a heavy heavy load (400th + GV) and have access to a good inexpensive GV, I would go 200 4R, 700R4, 4L60, 4L80. I had a GV behind a 350TH- tail of np205, worked great but I would not trade it for the 700R4 in my 67 4wd now - about half the cost of a rebuilt 350TH and a GV.
I will not recommend any trans rebuilder to you but I got my 700R4 from Monster - works great. Button on lockup and works like a 5 speed.
Only place I would put a GV is behind a stick now --- sold mine to wife's brother in law for his 6.5 diesel behind a sm 465.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T
dennislbrooks is offline   Reply With Quote
Old 07-21-2017, 09:00 AM   #7
72MARIO
72MARIO's Avatar
I had one behind a 400 one of the 2 worst things I did to my suburban its tied with my old air kit.
Swapped it out for a 4l80 so much nicer to drive now
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
