Old 07-16-2017, 08:52 PM   #1
64GMCpickup
8 lug to 6 lug 64 GMC, also V6 to V8 swap
I have a 64 GMC with 8 lugs and want to convert the front drums to disc.
I am installing a 6 lug Posi rear end (I already have it).
So, I need to install matching 6 lug discs in the front. Can I obtain parts from a newer model for a bolt on conversion? I would like to keep it as a 3/4 ton truck.
On another topic, are there bolt on mounts available for swapping the 305 V6 to a 350 V8? I would like to install the V8 and 700 R4 (I already have them).
Any thoughts you guys may have on this would be gratefully appreciated.
Thanks,
Steve
64GMCpickup is offline   Reply With Quote
Old 07-16-2017, 10:49 PM   #2
ImpalaJim
ImpalaJim's Avatar
Re: 8 lug to 6 lug 64 GMC, also V6 to V8 swap
well 6 lug is not 3/4
ImpalaJim is offline   Reply With Quote
Old 07-18-2017, 05:37 AM   #3
64GMCpickup
I am trying to match the 6 lug axels on the posi rear end. I would guess it would be rated as a heavy half ton ??????
Old 07-18-2017, 11:53 PM   #4
Captainfab
60-66 Nut
All GM 1/2 tons from '55-'70 were 6 lug. There was no such thing as a heavy 1/2 ton back then.
To change a '60-'66 3/4 ton to a 1/2 ton, you will have to change the entire front suspension including the crossmember from a '71-'86 C10 or a '87-'91 R1500. Then you will need the aftermarket 6 lug rotors.
Old 07-16-2017, 10:57 PM   #5
DPowers
One foot in front of the other
DPowers's Avatar
Welcome to the site.
FAQ section should give you all the info you need.
http://67-72chevytrucks.com/vboard/s...d.php?t=646002
DPowers is offline   Reply With Quote
6 lug to 8 lug, v6 to v8
