Old 10-25-2003, 01:26 AM   #1
79 stepside
79 stepside's Avatar
Need help with factory tach- '79 Silverado
After letting my truck sit for a couple of months, my factory tach quit working correctly. It is either at 0 or around 35. Any ideas or a plan of action would be appreciated.
79 stepside is offline   Reply With Quote
Old 10-26-2003, 12:09 AM   #2
Frank-id
tach no work
Hey we have the same truck. Show some pics. We can swap ideas.
The most common reason for a tach to stop working is poor connection at the distributor. Spray the distributor connections with lots of WD-40 or the best PB Blaster. Next check the fuses in the fuse block, and check for good ground at pass side rocker cover. Frank
Chevy stepper 400sb 350 turbo
Frank-id is offline   Reply With Quote
Old 10-26-2003, 12:20 AM   #3
79 stepside
Thanks for the ideas Frank. Those sound promising since it does seem to work, just incorrectly. Looks like you have a worthwhile project in front of you. Be sure and take pictures along the way.
My truck has basically looked like this for 20+ years, which the rollbar probably gives away. It always had 265 50's in front and 295 50's in back, but I needed it to be more of a truck again so I went with the stock rally wheels. As you get old, so does all the flash I guess. (by the way, that's 24 year old paint too. Gettin thin on the hood).
Jimmy
Jimmy
'79 Chevy Stepside
(purchased new in '79)
'67 Camaro
'97 Ford F-150
Diesels:
'80 Mercedes 300TD
'85 Mercedes 300TD
'77 Mercedes 300D (parts car)
Old 10-26-2003, 06:28 PM   #4
bigblock73
yeller
bigblock73's Avatar
Nice stepsides fellas.
I agree with frank, check the connections...sounds like they are loose or dirty.
-Jeff
bigblock73 is offline   Reply With Quote
