Old 07-19-2017, 04:48 PM   #1
Baker72chevy
Best way to clean this
What's the best way to clean those steering wheel
Baker72chevy is offline   Reply With Quote
Old 07-19-2017, 04:50 PM   #2
Graham57a
Graham57a's Avatar
Re: Best way to clean this
I used tire shine on mine, works decent
Graham57a is offline   Reply With Quote
Old 07-19-2017, 05:02 PM   #3
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Best way? A great source or two would say:
Clean it. Simple green should work, then wipe it off.
Sand the scratches out. Depending on scratch, start at 400 & work your way to 3000 o so. I'd be real careful with any 400. Take your time.
Carefully polish with white rouge & a soft flannel buff.
Treat it.
Admire your wheel.
I've only gone so far as sanding. Turned out nice.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 07-19-2017, 05:07 PM   #4
notsolo
notsolo's Avatar
GoJo Cherry with pumice works very well.
notsolo is offline   Reply With Quote
Old 07-19-2017, 05:23 PM   #5
dfwright
dfwright's Avatar
I assume this is the same wheel you said was blue paint on a black wheel? Do you want to keep the blue paint while removing the discoloration, or are you looking for methods to prepare for new blue paint?
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 07-19-2017, 05:53 PM   #6
Baker72chevy
I just wash it looks good to me what
You think
Old 07-19-2017, 05:56 PM   #7
Sklptrljay
Sklptrljay's Avatar
I'd probably go with simple green to get the dirt knocked off.
My body guy gave me a good trick to polish mine. Make a paste with Comet and a little water. Rub it out with a rag and you'll be surprised how nice it comes out. If you have deep scratches, you could use 2000 grit sandpaper before the Comet.
1971 C/10 SWB, 15x8 Rallys, 4.5" X 7" static drop, C-notched, 350/350, 3.73 Posi. .........A 383 and Gear Vendors are on my bucket list.
1972 GMC 4X4 K1500 Survivor - Sold
No matter what problems life throws at you, your time on Earth can be incredibly fulfilling and rewarding.....if you just lower your expectations. -Phil Dunphy
Sklptrljay is offline   Reply With Quote
Old 07-19-2017, 06:16 PM   #8
71CHEVYSHORTBED402
That's very cool. I'll have to test out that comet trick. Sounds like it would work. Seems baking soda would have a similar affect.
Tony
Old 07-19-2017, 06:43 PM   #9
Baker72chevy
I need to get a button where the best place I'm in ga
