Been awhile...refresher on timing please and thank you
So I have a stock gen1 sbc with an aftermarket hei
It's new to me with no real details , anyway I hooked up my light And at idle turned the knob until the balancer and tab zeroed out and got a reading of 34°? This is just with everything hooked up in running condition. I thought it would be a really low number between 10-18. Just wonder what iam doing because I've realized lately iam a ****y mechanic lol. I should plug advance and put in 30-34 ° before 3k and whatch out for detonation ? Must be doing something stupid because it wouldn't run like that and it runs pretty good? If you would please enlighten me I would appreciate it. Thanks Charlie |
Moderator
![]() ![]() Join Date: Aug 2011
Re: Been awhile...refresher on timing please and thank you
Tech paper on that - https://www.google.com/url?sa=t&rct=...xPU93aRTBZtX-w
Major info on that - https://www.google.com/url?sa=t&rct=...7Hdvbo1hQaQdxQ "...In order to measure this you must do two things. First, you must disconnect your vacuum advance and plug the port at the carb. Secondly, you need to be sure that your Mechanical Advance has not yet begun to advance your timing. This might happen if you have very light advance springs or your idle speed is too high...." Timing 101 - http://67-72chevytrucks.com/vboard/s...d.php?t=274806 More info - http://67-72chevytrucks.com/vboard/s...d.php?t=689321 I used "search" block upper right hand corner:
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 07-22-2017 at 02:50 PM. |
