Old 07-22-2017, 11:04 PM   #1
deereboy8r
deereboy8r's Avatar
1967 -1972 front bumper fog lights.
Hey I wanted to see if anyone would have some feedback on bumper fog lights as I have a 1971 truck with the 69-70 grill in it. I really like this grill and do not want to change it. I did need a bumper and came across a 1971-1972 bumper which if anyone knows has the parking lights in the bumper. My dilemma is the the 69-70 grill has the parking lights in it. So I was thinking of using this bumper with some fog lights in place of the parting lights. Just wanted to get your thoughts on it and attached the only photo I could find of this. Thanks for reading!
[IMG]
deereboy8r is offline   Reply With Quote
Old 07-23-2017, 12:57 AM   #2
toolboxchev
Re: 1967 -1972 front bumper fog lights.
That would be what my plan was.
toolboxchev is offline   Reply With Quote
Old 07-23-2017, 01:00 AM   #3
deereboy8r
deereboy8r's Avatar
Awesome man I don't see where it wouldn't look good I just didn't know if someone had some pics of it done.
Old 07-23-2017, 01:27 AM   #4
'68OrangeSunshine
'68OrangeSunshine's Avatar
I had a similar idea to use a '72 bumper with fog lights on my '68 C/10. I found out the '71-'72 support brackets were different from thw '67-'68s. A friend who had a chrome shop, traded me the '72 bumper for a chromed '68 bumper and his shop guys cut out square holes for my lights. Then I had a machinist make up some aluminum cones with an angle cut so I could mount my fog lights from a small hole in the bottom of the bumper.
Ran them on my '68 C/10 until the bumper got tweaked in a fender-bender.
A few years later, I straightened out the bumper [and fogs] and mounted on my '67 K/10 Suburban. Looked cool. Worked great until I was on a ski trip, and had everything on -- heater, fan, defroster, wipers. lights, stereo, CB, cop scanner, and foglights and wondered why my battery was going flat. I needed a bigger amped alternator to pull loads like that.
For limited duration, with fewer accessories on, it worked OK.
It's a cool gag. I had fun with it.
Old 07-23-2017, 02:26 AM   #5
deereboy8r
deereboy8r's Avatar
I hear ya yeah I think it will work good on mine since it is a 71 truck the bumper should work fine. I was just worried the lights in that place would look a little off and wanted to see some examples and I like to learn from others rather than spending the money and not being happy. But sounds like you like the look. I should be able to pick up the bumper for $50 so not too much to lose.
Old 07-23-2017, 03:44 AM   #6
'68OrangeSunshine
Make sure you get the bumper brackets along with the bumper if you have an earlier truck. The red Stepside in the first post isn't your truck? The frames do not change but bumper brackets do.
I'll try to shoot some pix of my ''custom'' bumper. [I couldn't find any in "Pictures'' on my computer.] They sized the cut-out to my lenses. '71-'72 parking lights are a little wider.
Some high tech LED lights might fit the stock hole, but won't look old school at all. Personally, I don't like the color temperature of LEDs. Too artificial. I like the old yellow look.
Old 07-23-2017, 03:50 AM   #7
deereboy8r
deereboy8r's Avatar
Yeah that truck ant mine that was the only example I could find on the web but here's mine don't look too bad but still needs a lot of work but yeah if you can send me some pics or post em here that would be awesome. Also I ant got the brackets I should be going to get the bumper tomorrow and will see if the guy has em if not I think I can get em for about 60 or so bucks. Don't wana spend it but gotta have em. I might try and find some on another truck though.
Old 07-23-2017, 07:06 AM   #8
notsolo
notsolo's Avatar
Couple other people have added fog lights / driving lights to the bumpers....http://67-72chevytrucks.com/vboard/s...d.php?t=322473
notsolo is offline   Reply With Quote
Old 07-23-2017, 08:54 AM   #9
deereboy8r
deereboy8r's Avatar
Thanks notsolo that silver one is what I am looking to do again thanks for the link!
Old 07-23-2017, 09:09 PM   #10
'68OrangeSunshine
Here's the front on my '67 Suburban:
Old 07-23-2017, 09:42 PM   #11
'68OrangeSunshine
Are you going to keep the 69-70 grille or use the 71-72 grille in the pic?
If you do use the 71-72 grille you will need front turn signals/running lights. You could mount aftermarket lamps behind the egg-carton grille. You will still need front-visible reflectors to be 1968 Fed reg compliant, I think. I used white 3M reflector tape on my front bumpers.
Old 07-23-2017, 10:57 PM   #12
deereboy8r
deereboy8r's Avatar
68OrangeSunshine I'm gonna run the 69-70 grill I just love that one and works great cause the truck is a 71 truck so I know the bumper will work.
Old 07-23-2017, 11:34 PM   #13
'68OrangeSunshine
Well the frames are all the same, it's the bumper brackets that differ. I don't know if 69-70 were the same as the Early [67-68] or Late [71-72] or their own thing. But you need the outer brackets for a '72. Unless you could fab your own from steel strap?
Old 07-24-2017, 06:50 AM   #14
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: 1967 -1972 front bumper fog lights.
My 71 with driving lights in the bumper. Cutout my self.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 07-24-2017, 10:51 AM   #15
harpo231
harpo231's Avatar
mine are round ones too
Stan
67 swb BLU MULE
posted via flip-fone
harpo231 is offline   Reply With Quote
Old 07-23-2017, 10:54 PM   #16
rusty knuckles 5
never thought of that, you should market that idea
rusty knuckles 5 is offline   Reply With Quote
Old 07-23-2017, 10:59 PM   #17
deereboy8r
deereboy8r's Avatar
rusty knuckles 5 I'd like to make an extra buck but I ant got the know how to market something nor the resources but if I get someone else started maybe they can send me a tee shirt of the business lol
Old 07-24-2017, 01:47 PM   #18
In The Ten Ring
I want fog lights on my truck too but I'm going the "old route" and just mounting them to the sides of the grill guard I bought for the front end.
In The Ten Ring is offline   Reply With Quote
