Old 07-26-2017, 10:44 PM   #1
Eastonspeedworks
Eastonspeedworks's Avatar
Factory tach mystery
So I have a rather odd issue with a factory tach/air pressure gauge I recently purchased. I previously had a sunpro tach I added into a stock tin that worked very well but didn't look quite factory. So tonight I installed the new dash everything went smoothly I got it all hooked up and everything was testing good until I started it to check the tach. It said it was running 500 rpm idle. I knew this wasn't right and the problem became more apparent as I revved the engine. The tachometer wasn't climbing like I was expecting so I hooked up my hp tuners software as its an ls engine and I confirmed my fear it was reading unproportional. Initially I thought I was sold a 6 cylinder tachometer not an 8 cylinder one. But looking at the numbers it's backwards the tachometer says 500 and the computer says 760 ish. The tachometer says 4500 and the computer says 6000. I did some research and found they can be calibrated with a screw on the backside but that seems to only change a set rpm. Anyone have any ideas? I'm a bit bummed out I spent an awful lot on this dash to go back to my old one
Eastonspeedworks is offline   Reply With Quote
Old 07-26-2017, 10:57 PM   #2
randy500
Re: Factory tach mystery
Let's see what others have to say...in my experience I have never thought the tachs were accurate at all. They seem very lazy, I have had dozens of them and thought that about most of them.
I tested 3 this week and one did seem more responsive than the others.
randy500 is offline   Reply With Quote
Old 07-26-2017, 11:00 PM   #3
custom10nut
custom10nut's Avatar
You should be able to get it closer by adjusting the screw on the back of your tach. It might not get perfect, but you should get close.
custom10nut is offline   Reply With Quote
Old 07-27-2017, 12:15 PM   #4
demian5
demian5's Avatar
Adjust it and see if its different through the range. Maybe the signal wire is not putting out true RPM?
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 07-26-2017, 11:19 PM   #5
Shinysideup
Shinysideup's Avatar
Maybe the needle wasnt put back on in right position.
._____________
..\ .___ . . . . _ . .\. . . . . . . . . . . ___
..| /_+_/ ___ |o| ...}. . . . . ______i__!\____
. [_____(O)_|_'|__}>-------[-_(O)__i'___i (O)-]
Originally Posted by 68 P.O.S. View Post
No thank you on that lifetime warranty. I don't want a turd for life.
Shinysideup is offline   Reply With Quote
Old 07-26-2017, 11:23 PM   #6
Eastonspeedworks
The trouble I have is the tachometer isn't just off 270 rpm at all ranges its off 1500+ at 6000 which doesn't work for me this thing rips and I don't want it stuck on the rev limiter all the time trying to guess what rpm I'm running.
Old 07-26-2017, 11:26 PM   #7
randy500
Well that LS revs way higher than 5k so your gonna need an aux tach anyway...
Old 07-27-2017, 12:28 PM   #8
toolboxchev
Your using modern technology with a 50 year old tach. So my thought is the signal coming from the distributor is the real issue.
Or just where is the signal for the tach generated from?
toolboxchev is offline   Reply With Quote
Old 07-27-2017, 12:32 PM   #9
demian5
demian5's Avatar
I thought the same thing, but he says the previous Sunpro Tach worked fine. Adjust and report back. Something is buffering the signal somewhere.
1986 C20 Scottsdale
Instagram: C10sofOC
Old 07-27-2017, 07:05 PM   #10
Eastonspeedworks
I should have a chance to try it out this weekend and see if the screw will tune it up. I'm wondering if it isn't a 6 cylinder tachometer though I seem to remember the signal from the ls computer is 4 cylinder but I don't remember switching the tachometer when I did the efi conversion. Guess I need to make a book on all my brilliant little ideas.
Old 07-27-2017, 07:55 PM   #11
AussieinNC
Moderator
AussieinNC's Avatar
I have seen this happen when the ECM was either setup to run the other tach within the software, or a voltage up resistor was added to the wiring to get the other tach to run on the reduced voltage output from the ECM...
Check in your tuner software to see if the Voltage Up setting in the ECM is set to On.
AussieinNC is offline   Reply With Quote
Old 07-26-2017, 11:29 PM   #12
Eastonspeedworks
That's a fair point I was hoping to shift it on the zero or the x at the bottom 😂
Old 07-27-2017, 12:03 AM   #13
randy500
I guess that COULD have worked....
Old 07-27-2017, 12:30 PM   #14
clay68c10
clay68c10's Avatar
I had to adjust the tach on a former truck of mine, and as I recall, it was off similar to yours. A little at idle, and more as the RPM increased. I adjusted it to be close at 2500 and that seemed to fix it at all RPMs. It was never REALLY accurate, but that's what the laptop is for.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 07-27-2017, 08:35 PM   #15
AussieinNC
Moderator
AussieinNC's Avatar
No Worries Mate !
havagoodweegend
Old 07-27-2017, 10:13 PM   #16
clay68c10
clay68c10's Avatar
Is there a shift light output option for your ECU? I'm running EBL flash on a couple of my dinosaurs with TBI and that is an option I've used. Then you can hide a light, or repurpose one of the idiot lights in your cluster.
13 Tahoe LTZ
Old 07-27-2017, 11:14 PM   #17
Eastonspeedworks
There is an option for a shift light but I don't have any cluster wiring with the aftermarket harness. I'd have to pin it out to find it but that would be a pretty cool idea to have an idiot light for a shift light I'll do a bit of research on that one thanks for the idea!
Old 07-29-2017, 12:10 AM   #18
Eastonspeedworks
I owe a huge thanks to aussieinnc. That fixed the tach within 200 rpm through the whole sweep if it didn't require a whole number I'd have it perfect but its darn close anyways. I'll add a shift light like clay68c10 suggested when I replace the seat. All the wiring is underneath it. Thanks for everyone's help!
Old 07-29-2017, 03:02 PM   #19
AussieinNC
Moderator
AussieinNC's Avatar
More than welcome mate....havabeerforme....
Old 07-30-2017, 08:39 AM   #20
70 shorty
Where's my beer?
70 shorty's Avatar
So, do you shift on the 0 now, lol???
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam.
79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam.
'03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great
'08 Tahoe LTZ 4x4 155K
70 shorty is offline   Reply With Quote
Old 07-30-2017, 08:43 AM   #21
Eastonspeedworks
I'm going to take it out today and give it hell! I've got the speedometer back to zero before why not the tach? 😂
