07-27-2017, 04:05 PM | #1 |
What's this brake component called?
Though I'm approaching a full take-off, as I've said before, somehow I've avoided ever doing a brake job. At any rate, what is the unit called where the rear brake line tube connects?
While at it, what's the "plate" bolted onto the axle called. Thank you, Novice
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
07-27-2017, 04:08 PM | #2 |
Re: What's this brake component called?
wheel cylinder , backing plate
Stan 67 swb BLU MULE posted via flip-fone |
07-27-2017, 04:21 PM | #3 |
Old member
Back side of the wheel cylinder that puts pressure to the brake shoes.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
07-27-2017, 04:26 PM | #4 |
Wheel cylinder and backing plate........Noted, thank you
07-27-2017, 04:31 PM | #5 |
Np
07-27-2017, 04:41 PM | #6 |
I should have asked beforehand, how about the "equivalent" for the fronts, only disc brakes? I get to pull those lines next.
Can't wait to dive into the brakes (ha), and that's coming in somewhat short order. I hear they're easy. I don't know, looks like a lot of parts, but doable. Plenty of videos on the web.
07-27-2017, 04:49 PM | #7 |
lines hook into caliper , rotor mounts on spindle
07-27-2017, 05:24 PM | #8 |
Thank you again. Appreciate it.
07-27-2017, 06:50 PM | #9 |
Only take one side drum setup apart at a time--that way you can look at the other side when you don't remember where all the bits go...
07-27-2017, 08:36 PM | #10 |
That and I'll be taking some pictures, thank you.
