Old 07-28-2017, 08:42 AM   #1
pappy 2
Suspension Question
Lowering the front 4.5 inches . As I was cleaning up lower 'A' arms yesterday, I had the idea to maybe remove the rubber bumper perches that the rubber is attached to. Maybe find another style of rubber bumper to use that would set lower on the A arm. Has anyone seen this modification done or maybe done something similar? Thanks for you input.
pappy 2 is offline   Reply With Quote
Old 07-28-2017, 09:15 AM   #2
clay68c10
clay68c10's Avatar
Re: Suspension Question
I say try it!
Mock up one side with no spring and see what the clearances are at full compression.
Maybe you could remove the portion of that perch and just cut a slot to mount the original bump stop in the arm. Or make it even, it steps up to hold the bump stop from the level of the steering stop.
Let us know what you find.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 07-28-2017, 10:30 AM   #3
Boog
laying low
Boog's Avatar
If you remove the spring then raise the control arm assembly i think you will find a point where the ball joints bind. Thats where you will need the bump stops. You may get by with only shaving a little off the rubber stop.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
