08-15-2017, 11:41 PM | #1 |
66 C50 aka Big Orange
So I had a 62 C50 2 years ago that I wanted to build to be a hauler/pulled but decided it needed way too much work so I decided to sell it. Within a year pics pop of of Dino's C50 which is basically what I was going to build. So it's been killing me. I live near Dayton Ohio and although there are a lot of farms around there aren't many of these trucks (I was only looking for a 60-66).
I ended up finding this 66 C50 locally. It has 30k original miles on a 292 with 4spd. It does not have the 2speed rear end. The previous owners paid $6,600 for it in 2003 and then recently put all new wheels (no more 2 piece) and tires, new brakes all the way around, a brake booster, new starter, and battery. The E-brake quit working so they decided to sell it. I snagged it for $1000 and drove it home. Worst part of the truck is the front cab mounts are shot so I'll be doing those and some floor work. I'd like to lower the truck or possibly lay it on the ground. I have a 92 chevy short bus that I can use for a donor. I measured wheel width and they are pretty much identical. Doing a quick measurement it looks like the frame widths are basically the same also (I'll have to check more closely later). So now the debate is swap the cab onto the short bus frame or swap the front suspension over from the bus to the 66. Biggest issue for me currently is that the bus has 10 lug 16" wheels. I can't run that small of wheels on the 66 so I kind of want to figure that out first!
63 1ton Paneltruck build: http://67-72chevytrucks.com/vboard/s...d.php?t=627721 Instagram: jaked937 |
08-15-2017, 11:43 PM | #2 |
Re: 66 C50 aka Big Orange
I hate how some of the pics post sideways or upside down. Sorry, I just upload them from my phone.
08-15-2017, 11:44 PM | #3 |
Here's a pic of it next to my 63 panel that lays door.
08-15-2017, 11:45 PM | #4 |
Another attempt to get a straight pic.
08-15-2017, 11:47 PM | #5 |
Used the C50 to haul some sand to a piece of water I have access to.
08-15-2017, 11:47 PM | #6 |
I nephews loved it.
08-16-2017, 09:18 AM | #7 |
awesome!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
10-17-2017, 01:18 PM | #8 |
Scrapper 1
I hope when i got back to Utah I hope i can fine one of them really miss not being around them old trucks.A c50 or c60 would do
04-26-2018, 07:12 PM | #9 |
Finally started working on the truck. Tore it down.
04-26-2018, 07:13 PM | #10 |
Starting swapping axles from a 92 Chevy G30 short is I had. Added some 22” Alcoa’s on it.
04-26-2018, 07:17 PM | #11 |
Overall I’d like this truck to sit fairly low,I may even bag it, and I decided that it was going to be easier to do a cab swap onto a C30 frame than it would be to cut up the original frame. I picked up a 78 C30 frame for $300
04-26-2018, 08:57 PM | #12 |
Im in to see this .
05-08-2018, 09:49 AM | #13 |
Got the cab mounts fixed and the cab swapped to the 78 C30 frame. That lowered the body around 6”. Pics are of the truck without the 1000lb Cummins that’s going to go in it.
05-08-2018, 09:52 AM | #14 |
Started working on making some engine mounts. Made from .5” and .25” steel. The Cnc plasma table makes easy work out of it.
05-08-2018, 09:56 AM | #15 |
Need to make a transmission mount and finish welding the engine mounts but it’s mainly mounted. 1000lb Cummins squatted the front end 1.5”. That should put my side steps around 6.75” from the ground before the 3” drop spindles I need to install. Hoping to upgrade the wheels to 24’s or at least getting a bigger profile tire. 35 series looks too rubber bandish
63 1ton Paneltruck build: http://67-72chevytrucks.com/vboard/s...d.php?t=627721 Instagram: jaked937 Last edited by Free Candy Inside; 05-08-2018 at 12:50 PM. |
09-23-2018, 11:12 PM | #16 |
I’ve kind of abandoned this thread and have been posting my progress here.
http://67-72chevytrucks.com/vboard/s...d.php?t=764215
