08-17-2017, 06:54 PM | #1 |
Door seal problem
I put new door seals on my 65 but now it's really hard to shut the doors. Anyone else have this problem? If so what did you do to correct it ?
08-17-2017, 07:29 PM | #2 |
Re: Door seal problem
Common problem on just about every aftermarket weatherstripping, cars or trucks. Usually, buying the softest available helps. But, short of experimenting with every brand out there, try this:
I strategically bent the pinchweld inward slightly to allow the rubber to just touch the door. I did this during the mock-up stage before paint so I wouldn't have to worry about damaging the paint. |
08-18-2017, 02:55 AM | #3 |
I know it's a little late now but the absolute best solution for door weatherstripping on our C-10's is off a 2006 Honda Civic. Check out this link:
http://67-72chevytrucks.com/vboard/s...d.php?t=617703 |
08-18-2017, 10:31 AM | #4 | |
Never Ending Projects
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
08-18-2017, 11:03 AM | #5 |
I used press on seals and had zero issues . Door closes solid.
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
08-18-2017, 11:40 AM | #6 |
I just got the ones from lmc the push on ones. Will see what happens.
08-18-2017, 10:32 PM | #7 |
I have the push on ones from Brothers truck. They work great and the door shuts easy just like factory.
John Z 1962 Chevy C10 Stepside 62 Barnfind My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513 |
08-20-2017, 02:09 PM | #8 |
Im ordering a set from Prescott Honda tomorrow. Got my door jambs stripped and primered yesterday and dont want to use glue again.
Changed my mind and ordered a set from Brothers last night. $30 cheaper for the set. Last edited by 65chevysub; 08-21-2017 at 06:34 AM. Reason: adding text |
08-21-2017, 07:37 PM | #9 |
Your going to love them!
08-22-2017, 05:39 PM | #10 |
08-23-2017, 04:34 PM | #11 |
08-20-2017, 04:12 PM | #12 |
http://67-72chevytrucks.com/vboard/s...d.php?t=721217
I have no issues with Precision push on seals.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
08-20-2017, 05:12 PM | #13 | |
Moderator
08-20-2017, 08:04 PM | #14 |
Its hard to keep up with these young kids. lol
08-20-2017, 08:26 PM | #15 |
what is the website for GMCPaul's? I tried to do a search and it came up with every GMC dealer with the name Paul in it and thats all
Thanks |
08-20-2017, 08:40 PM | #16 |
What part are you looking for?
08-20-2017, 10:31 PM | #17 | |
http://www.gmcpauls.com/60-66_exterior.htm |
08-20-2017, 08:48 PM | #18 |
Moderator
08-22-2017, 06:58 PM | #19 |
Thanks for the info guys. I wish I had known about the Honda seals before I bought the ones I have.
