Old 08-22-2017, 12:37 PM   #1
Matt58
1966 Stock 4x4 chassis
Recently picked up a 66 K10 short fleet and would like to see some pics of front and rear stock suspension so i can compare to what i have. Thanks
Matt58 is offline   Reply With Quote
Old 08-22-2017, 01:52 PM   #2
61K10
61K10's Avatar
Re: 1966 Stock 4x4 chassis
Post some pics of what you have. Might get more info. My 61 is a little different in shock mounting.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 08-23-2017, 12:52 AM   #3
'63GENIII
'63GENIII's Avatar
Agreed. We're a bunch of picture mongers! Seriously though, you'll probably get more responses with a handful of pics of what you have.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 08-23-2017, 11:20 AM   #4
Matt58
thanks guys i will try to get some pics for you....
Old 08-23-2017, 06:17 PM   #5
Matt58
here they are
Old 08-24-2017, 02:27 AM   #6
'63GENIII
'63GENIII's Avatar
From memory it looks identical to what my '63 came with.
Closed knuckle Dana 44
T221 T case
12 Bolt rear - This is the only difference I could see. It looks like the shock mounts on top have been moved inward towards the center and that the lower mounts (the ones hanging down off of the axle) have been abandoned and relocated?
Chris
'63 k15 long step
Old 08-24-2017, 01:07 PM   #7
61K10
61K10's Avatar
Like Chris said looks factory stock. Just for info some pics of my shock mounting as yours looks modded. can't really tell. My top ft shock mounts are modded. (pic of the ft mounts i cut off) Your ft shock upper mount should go through the frame.
1961 chevy K10
Old 08-25-2017, 09:35 AM   #8
Matt58
Thanks guys. Good to know its mostly original under there...
Old 09-11-2017, 05:41 AM   #9
j.kirn
your frame looks to me like it is a 60-62 frame, with newer rear axle
j.kirn is offline   Reply With Quote
Old 09-11-2017, 12:26 PM   #10
61K10
61K10's Avatar
I think you are right Joe. Looks just like my 61 frame. rear upper shocks are like mine and it has a front motor mount on the x-member.
1961 chevy K10
