Old 08-24-2017, 08:53 PM   #1
JMC1965
JMC1965's Avatar
It's been a long time...new to me C20
Greetings,
my first car ever was a 1969 C10 that I received from my grandfather. It was a rusted out, used hard country truck....and I loved it.
Through the years I always told myself I'd have another 67-72 truck when I had the time and money to do it.
Fast forward 30 years...a few kids later that time has come.
So here's what's happening...I travel a lot for work...so I'm having a local shop work the big stuff for me...otherwise it would be another 30 years before I could drive it.
I followed the advice of the forum...if you don't have the garage space, tools and/or time...buy the best truck I can afford before starting.
So I did.
The PO did a good job w/ it...frame off clean up...straight body...
new crate 350 (364 miles on it), TH400, wood bed, new A/C, new carpet, twin electric fans, new steering column, Dakota Digital dash, and refinished bench seat
So for all that...whomever you are PO...I thank you (I got if from a dealer...who got it as a trade)
Not everything that was done was something I would have done (e.g. cowl induction hood with racing stripe)...but heck...the PO did a nice job so I'm keeping it for a while
Now I'm going through to make it my main vehicle when not traveling.
going to attached the pics from dealer to get going....then post updates
JMC1965
1967 C20 LWB
  • 350 (ATK-HP32) / FiTech EFI
  • 4L60e / 4 wheel disc brakes
  • 20" American Racing VN327 & 245/50/20 Michelin
JMC1965 is offline   Reply With Quote
Old 08-24-2017, 09:09 PM   #2
JMC1965
JMC1965's Avatar
Re: It's been a long time...new to me C20
So here's the analysis from driving the truck a few days, making a "fix/do list" and prioritizing the list....
  1. It starts right up...that's good
  2. I goes forward, reverse, stops...
  3. the A/C blows cold (good have in TX)
  4. The gauges have electrical power to them...none are accurate
  5. the firewall is not finished...ie, there are not plugs, grommets, etc...
  6. the carrier bearing is shot
  7. there are no windshield wipers (knew that from pics...but on the list)
  8. afterrmarket steering column is from a column shifter (even though the shifter is on the floor)...so it's about 3-4 inches further to driver than it needs to be..it's tight
  9. it's loud...way loud...small muffler, dumped at axle
  10. the headers are not correct for the plugs (burned wires)
  11. windows mechanisms need to be replaced or greased
  12. vent windows are not "completely" installed (missing 3 screws at top of door)
    all that said...I LOVE IT
    few more pics from dealer
JMC1965
1967 C20 LWB
Old 08-24-2017, 10:13 PM   #3
JMC1965
JMC1965's Avatar
sorry for the quick posts...just getting through all the notes....
  1. Power steering works...but steering box needs to be rebuilt
  2. small oil pan leak (...cork gasket)
  3. A/C duct on passenger side not connected properly
  4. A/C ball housing outlet on passenger side broken
  5. A/C cable to blend door needs adjusting
  6. Front suspension bushings worn out
Here's the to-do list
Mechanical
  1. FITech EFI
  2. Change to OD transmission
  3. Full conversion to disk brakes
  4. Move gas tank to under bed
  5. Lower rear gear ratio (going to be highway driving)
  6. Change to correct headers and replace burnt spark plug wires
  7. H-pipe, and run exhaust out under rear bumper and get a "closer to stock" muffler
  8. Lower rear end (front already mechanically lowered 2 inches...I want it leveled)
Well...that the start of the list...let me see how far this comes along
JMC1965
1967 C20 LWB
Old 08-25-2017, 07:45 AM   #4
JMC1965
JMC1965's Avatar
  1. FITech...in
  2. Tank out of cab...new tank should be in this weekend
  3. Damplifier Pro on cab floor and firewall (so far)
  4. Disk brakes in....got to run the lines
  5. 4L60E Stage 2 is in w/ new shifter
Drive shaft.....based on the reading from the forum here...I'm going aluminum one piece. the geometry works for me
Wheels should be in next week. AR VN327
JMC1965
1967 C20 LWB
Old 08-25-2017, 09:39 AM   #5
68Gold/white
Way cool!!!
After all those mod's I'd want front disc brakes!!!
68Gold/white is offline   Reply With Quote
Old 08-25-2017, 10:48 AM   #6
JMC1965
JMC1965's Avatar
oh yeah....full disc brake conversion....4 wheels. It's being done. front and rear suspension are out getting their work done now
I kinda splurged on the rear axle...new Quick Performance 9" w/ TrueTrac...3.5 gear ratio...and disc brakes.
pics....old stuff front and rear out....new QP rear axle in...still need to figure out the shock angle. Panhard bar is in also..but pic was taken before that.
PS: did a lot of research before starting this...this forum has some gifted, talented, and very knowledgeable people. Thanks to everybody
JMC1965
1967 C20 LWB
Old 08-25-2017, 02:02 PM   #7
68Gold/white
Staying with 3/4 ton?
Old 08-25-2017, 03:15 PM   #8
JMC1965
JMC1965's Avatar
well....switching to 5 lug...so I guess no to the lugs. It's hard to know what the PO did...he dropped the front either by replacing or cutting springs. the helper leaf in the back is there and the springs in the back look to be the hefty variety.
JMC1965
1967 C20 LWB
Old 08-25-2017, 05:56 PM   #9
JMC1965
JMC1965's Avatar
New headers are in....
JMC1965
1967 C20 LWB
Old 08-26-2017, 05:05 PM   #10
JMC1965
JMC1965's Avatar
Gas tank is in....
waiting on driveshaft and AR wheels (shop wheels on it now)....
JMC1965
1967 C20 LWB
Old 10-06-2017, 08:11 PM   #11
JMC1965
JMC1965's Avatar
this is bad....right?
#8 plug is oil fouled....crap
Got new engine today
JMC1965
1967 C20 LWB
Old 10-07-2017, 11:09 PM   #12
Aus69c20
Aus69c20's Avatar
Lookin good. Crate 350 I assume?
John
69 c20, 396, th400, dana60, ps, ac
Aus69c20 is offline   Reply With Quote
Old 10-08-2017, 02:56 AM   #13
GR8-68
GR8-68's Avatar
Great looking build and some fine work and quality choices. Keep up the good work.
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline   Reply With Quote
Old 10-08-2017, 03:53 PM   #14
JMC1965
JMC1965's Avatar
ATK HP32C engine. 350 with Vortec Swapping carb to use my FITech from other motor
So far installed and fired up
JMC1965
1967 C20 LWB
Old 11-03-2017, 10:19 PM   #15
JMC1965
JMC1965's Avatar
ok...got the stance correct....GMCPaul's 4 inch 3/4 ton springs in the back. Not sure what the PO had done to the front to drop...but appears the springs were cut. So....they guys trimmed another bit to give me 3/4 inch more drop.
Shock relo installed...thanks to the members and especially Andy4639 for info on their set up.
Pics...new stance...new steering column.
JMC1965
1967 C20 LWB
Old 11-05-2017, 06:33 AM   #16
Aus69c20
Aus69c20's Avatar
Looks great
John
Old 11-05-2017, 09:21 AM   #17
GR8-68
GR8-68's Avatar
very nice ride you have there
Larry
"Project 68"
paypal.me/ldgrant
Old 12-20-2017, 11:47 PM   #18
JMC1965
JMC1965's Avatar
Alright ...been driving around town for a while and now I’m going on the first road trip. Taking it a couple of hours down the road. I’ve read the forum and prepared my truck travel kit, AAA card, and cell phone ready.
JMC1965
1967 C20 LWB
Old 12-21-2017, 09:12 AM   #19
hewittca
hewittca's Avatar
Nice work! You definitely made some improvements to an already nice truck. The new stance looks great. Good luck on your first road trip! I know I'm always nervous when taking my truck out after some major changes.
Builds: Green Gus the 68 C10 | Bluey the 72 1500 | Lowly the 70 C10
Instagram: @dr.hewitt
C10 Concept/Development Photos: Master Thread
hewittca is offline   Reply With Quote
Old 12-21-2017, 01:23 PM   #20
JMC1965
JMC1965's Avatar
Made it....
took one stop along the way to check fluid and stretch out.
It ran like a dream...wind noise and all.
Got some work to do on AC still (yep...needed it today in Texas).
JMC1965
1967 C20 LWB
Old 12-21-2017, 01:31 PM   #21
Orange67
Orange67's Avatar
Awesome truck man. Love the stance.
Justin
'67 C20 CST Custom Camper
'04.5 LLY Duramax CCSB...sold
Orange67 is offline   Reply With Quote
Old 12-21-2017, 01:34 PM   #22
JMC1965
JMC1965's Avatar
Thanks Orange67. Got to thank GMC Pauls for having C20 drop springs....that let me remove the blocks and clean up the look.
JMC1965
1967 C20 LWB
Old 04-20-2018, 05:39 PM   #23
JMC1965
JMC1965's Avatar
Been a while....so here's the latest.
electrical problem fried the controller for gauges the PO put in...so I didn't waste the opportunity to upgrade (surprise)
Dakota Digital HDX....after reading LockDoc and Andy4639 post about their GPS speedometers that's the way I went
I tried to get too fancy and incorporate an additional unit...so I had to back off and just do the gauges and the GPS controller.
it's in...it also has the bluetooth system controls on my phone...gauge readouts, and lighting changes
also put in the JW Speaker LED headlights...need to adjust one of them...but they really light up the road...good upgrade. pricey but a good upgrade.
JMC1965
1967 C20 LWB
Old 01-25-2019, 09:52 AM   #24
JMC1965
JMC1965's Avatar
well....after months of fighting electrical gremlins and running in circles I gave in. I called my friends at CNC Customs here in Dallas and have them rewire the whole truck.
got it back last week. runs great, drives great, no issues.
Next up refinishing the wood bed!!!
JMC1965
1967 C20 LWB
