Old 08-28-2017, 11:58 AM   #1
forestb
forestb's Avatar
How maney cores
I am trying to figure out how many corers the original radiator for my 62 has. It is around 2-3 inches thick. The finned part of the radiator is the same thickness as the top part that the upper hose connects to.
forestb is offline   Reply With Quote
Old 08-28-2017, 12:02 PM   #2
forestb
forestb's Avatar
Re: How maney cores
Here are two photos. I don't have a side photo.
Old 08-28-2017, 03:38 PM   #3
LVPhotos
LVPhotos's Avatar
Re: How maney cores
If original v8 should be 3 or 4. I was told my 62 core was a V flow, not cross flow. Cools better. So if a good core do not replace! I Run a 406 small block in Vegas heat with my stock radiator.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 08-28-2017, 03:44 PM   #4
LVPhotos
LVPhotos's Avatar
Re: How maney cores
Heres my Flex-a-Lite Black Magic 3300cfm fan
Old 08-28-2017, 03:49 PM   #5
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: How maney cores
My 65 is on a 62 Gmc Frame. It had a 351 V6 in it. When I went to a V8, I used the GMC V6 Radiator. It's still in there to this day:
[/QUOTE]
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 08-28-2017, 04:01 PM   #6
LVPhotos
LVPhotos's Avatar
Re: How maney cores
Is that factory Shroud? I did not have one but used the 6 tabs to mount this fan
Old 08-28-2017, 05:19 PM   #7
Llay R. Rac
Llay R. Rac's Avatar
Re: How maney cores
my original radiator is a 3 core, the core is 2 inches thick and the tank is 3
take off the rad cap and you can see or feel the number of rows.
I've been researching replacement radiators , it seems the size of the core is important, ie a 4 core with smaller diameter cores may not cool as well as a 3 core with larger cores.
1965 Suburban, 2 wd.,292, 4-speed.
proudly owned and operated since Valentines day 1969.
Llay R. Rac is offline   Reply With Quote
Old 08-28-2017, 06:15 PM   #8
LostMy65
LostMy65's Avatar
Re: How maney cores
The Shroud in my pic above is the original 62 Shroud.
