Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 08-29-2017, 11:22 PM   #1
Another 72
Another 72 Build Thread
Hello all! I've been trolling the forum pages off and on for a while now, ever since before I even purchased my 1972 K5 Blazer. I've managed to garner a little knowledge off the site - which is saying a lot for me - and I figured it was time to give back a little. I know how much everyone loves a good build thread, but welcome to mine anyway. LOL!
Still reading? Well, let's start from the beginning. First of all, like my yet to be introduced K5, I'm a 1972 model myself, so I guess I have an illogical affinity for my 1972 K5. At least the later models tend to be better equipped, i.e. front disc brakes.
I joined the Air Force in 1993 and was stationed at Malmstrom Air Force Base, Montana. Wonderful place, cool job fixing communications gear out at the (then) 220 missile and missile control sites. My 1968 Mercury Cougar wasn't much good in the winter, and an ochre 1972 with a white fiberglass top and 235/75/R15 "baloney skins" (bald tires) on the used car lot for the lofty price of $2500 caught my eye. Remarkably, it was still there after hunting season, so I stole it for $1800. The one below isn't mine, but the one I used to have looked a lot like this:
Rob
"1967 Wanna Be" 1972 K5 Blazer
Another 72 is offline   Reply With Quote
Old 08-29-2017, 11:32 PM   #2
Another 72
Re: Another 72 Build Thread
After nearly ruining the truck with a budget 2-inch add-a-leaf, a 3-inch body lift, some white wagon wheels, and some 35 X 12.50 BFG All Terrains, it looked a lot like the truck below. I probably should have re-geared it and retired the old 307. Keep in mind I was a young airman at the time bringing home about $400 every couple weeks. I soon got the bug for extended cab, super cab, and crew cab full size 4X4 pickup trucks, so the Blazer had to go. I sold it for $3500 and have always regretted it. Again, the truck below isn't mine, but the stance is very comparable.
Rob
Old 08-29-2017, 11:50 PM   #3
Another 72
Over the past 20+ years the Air Force has taken me all over the world, and I've owned a lot of cool old rides. After the K5 Blazer, I owned a 1979 F-250 XLT Ranger Supercab 4X4, a 1978 XLT Ranger Bronco, a 1973 Bronco, a 1971 Wagoneer (transplanted onto a shortened 1984 3/4 ton Suburban frame), and a 1967 F100 stepside (2wd). Along the way my old bright red 1968 Cougar was totalled by a half-blind old man driving a yacht, and I more or less lacked the heart to take on an old car again, but I did let a 1968 XR-7 "hangar queen" take up space in my garage for the longest!
Eventually, I'd had enough - I HAD to right the wrongs and get another old K5 Blazer, and in November of 2015 I purchased one on e-Bay. It was in South Dakota, I'm in Virginia. But before I could take delivery I had to sell the 1967 F100. It kept the wife happy...little did se know that I had already purchased the K5...but I think she figured it out when the K5 showed up in February of 2016. Here's my 1967 heading to its new home:
Rob
Old 08-30-2017, 12:29 AM   #4
Another 72
Below is my 1972 K5 Blazer as it looked when I took delivery in February of 2016. Its a North Dakota truck (I think I stated South Dakota before), so rust is manageable. It had a homemade 1/2 top with a sheet metal wall welded in behind the front seats - those were the first to go.
Rob
Old 08-30-2017, 07:04 PM   #5
tjsblazer
tjsblazer's Avatar
I'm in for the ride. Looking forward to another.
Jeff.
'72 Blazer K5
"Camshaft opinions are like belly buttons; everyone has one and no two are alike"
My Blazer Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=626752
My Engine Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=637336
tjsblazer is offline   Reply With Quote
Old 08-30-2017, 10:04 PM   #6
Another 72
Thanks, Jeff. My build isn't going to be anywhere near as detailed as yours, not yet anyway.
The first thing I did with my Blazer was lose the crappy, homemade half-top and sheet metal wall behind the front seats. Now I wish I would have kept the front part of the half-top - I saw a thread on here recently where someone used the front of the top to attach soft top snaps without drilling the windshield frame. It looked a little odd but was probably great at keeping out leaks and precluding a PITA soft top/hard top transition.
Before I ditched the half-top, I located a usable fiberglass top in southern Pennsylvania - it's a double-wall so it's a bit heavier than I the single-wall was on the Blazer I had in the 90s. Then again, I was 22 years old back then.
I didn't trust the bottom wall of the top to hold the top down if I ever got the Blazer up to speed with the windows down, so I drilled holes in two pieces of 1/8" thick, 3/4" wide, 3-ft long steel on each side with 3/8" nuts, bolts, and oversized washers underneath (grade-5 or maybe grade-8).
On another note, the bedside holes didn't line up properly, leading me to think my truck originally had a single-wall top. Then again, I may have read somewhere that trucks assembled at different plants might not have had the holes in the same location, but this seems unlikely as the original hardware (heavy captive rectangle nuts) was more or less permanently attached. I'm sure someone else here knows way more about that.
Rob
Old 08-30-2017, 10:31 PM   #7
Another 72
Like most of us, I'm not 20 years old anymore, and the idea of climbing in and out of a truck 7 feet tall with 35-inch tires isn't nearly as appealing as it used to be. Plus, I'd like this thing to be HALFWAY practical again. So, off come the 8-lug 3.73 or 4.10 or 4.56 or whatever geared Dana 60 full-floater rear and Dana 44 disc brake front, probably from an early or mid 1970s Chevy 3/4 ton. Hint, hint - anyone interested in these axles? Anyway, the spring pad width matched my Blazer. I think the rear is also wider than original 12 bolt rears, so they position the rear wheel nicely to match the front. I never noticed on my old Blazer 20 plus years ago, but the front axle is 4 inches wider than the rear, meaning the rear wheels sit 2 inches inside the quarter panel relative to the fronts.
I sourced some original 6-lug axles - a GM 12 bolt rear and a Dana 44 front - from a fellow forum member - thanks Dwayne! I haven't verified yet, but they're probably the 3.07 3.08 geared axles, which is okay because I'm currently running the granny-low 4-speed. The plan is to eventually swap in a 5.3 (or 4.3 EcoTec) with 6-speed automatic which will keep my 1st gear ratio at 12.4:1, which I think is good for stock height, 31-inch tires, 250-300 horsepower, slightly more torque than HP, in a vehicle weighing nearly 4,000 pounds.
I know what some of you will say, but I'm interested in hearing OPINIONS on this.
Great website for gearing calculations:
http://www.grimmjeeper.com/gears.html
Rob
Old 08-30-2017, 10:40 PM   #8
Another 72
Thanks Jeff, that makes way more sense. By the way, I like daydreaming about fabricating an aluminum top after I'm done with EVERYTHING else (which might NEVER happen). I guess I better hurry up on this build - if I'm going down THAT road I better do it before I'm in my 70s!
Rob
Old 08-30-2017, 11:07 PM   #9
Another 72
Hmm....going back to the Grimm Jeeper gear ratio calculator, I can see some 3.55 gears in my future. I think that would match extremely well with 300 HP, 300+ ft/lb, and a 6l80 in a 4,000 pound vehicle. This line of thinking occupies WAY too much of my processing power!
Rob
Old 08-30-2017, 10:30 PM   #10
tjsblazer
tjsblazer's Avatar
I too think that holes should align regardless of the Assembly line because of the top.
Double wall tops have the nuts in them bolting up through the bedside so from the factory the truck bedside was drilled with holes only.
Single wall tops have holes only bolting down through the top in to captive nuts welded on the the underside of the bed rail.
Since in '72 they used both the double and single walls some Blazers from that year have bedsides drilled for both.
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 08-31-2017, 10:01 PM   #11
DeadheadNM
Carpe manana
DeadheadNM's Avatar
I'm on board! Any chance you overlapped with a colonel Keen while in MT? He may have been retired by 93. Pete
Old 08-31-2017, 10:06 PM   #12
Another 72
Pete,
I don't know, did he have a daughter?
I was there from 1993 to 1996, but to be honest I tended to steer clear of colonels back then!
Rob
Rob
Old 08-31-2017, 10:26 PM   #13
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Lol! He did. He's my uncle. Eager to watch your build. Off to a great start Rob.
Old 08-31-2017, 10:32 PM   #14
DeadheadNM
Carpe manana
DeadheadNM's Avatar
All 72s had provisions for both single (caged nuts) and double wall (holes) tops. If your blazer was a St Louis build its very likely it had a double wall top: early Flint built K5s had 2x wall then Flint switched to single wall.
Old 08-31-2017, 10:54 PM   #15
Another 72
Good to know. I removed the caged nuts - most of them were falling out or severely rusted anyway. I think I had to drill some holes for the doublewall, but maybe I just expanded the holes.
Rob
Old 09-03-2017, 12:39 AM   #16
Another 72
No wrenching today, but I did purchase a good, clean OEM grill and OEM hood, as well as some Goodmark inner fenders. Monday morning I'm picking up OEM fenders and OEM core support. Monday afternoon or Tuesday morning - depending on family plans - I hope to dismantle my 1972 front end sheetmetal. Or maybe I' should finish bending, flaring, and installing the rear brake lines, bleeding the brakes, sealing the rear diff, adding gear oil, and driving around the neighborhood (no bumpers).
Decisions, decisions!
Rob
Old 09-03-2017, 08:10 AM   #17
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Those new wheels look nice. Someone is sure to want those slots though.
Tom Vogel is offline   Reply With Quote
Old 09-06-2017, 07:30 PM   #18
Another 72
Thanks Tom! Love the stance on your Jimmy! The old wheels went with the tires. Enjoy, Trey!
Rob
Old 09-08-2017, 12:24 AM   #19
Another 72
Light day today, but I managed to prep and primer my 67 core support - at least I think it's a 67/68. Maybe someone on here can verify. I also have a little rust to patch on the bottom of the core support, I think on the battery/passenger side.
Rob
Old 03-28-2019, 07:39 PM   #20
Another 72
Well, I guess it's about time to revive the build thread. Just like basic training, the first step is tear down, and over the past 18 months I've removed and sold the front sheet metal as well as the engine, tranny, t-case....basically it's a 1972 Blazer cab and top on a rolling frame.
I finally tried my hand at welding. Remember that rusted out 1967-1968 core support? I think the repaired core support looks plenty good enough to go between the grille and the radiator. LOL.
Rob
Old 03-28-2019, 08:56 PM   #21
Another 72
Since the core support repair went so well, I figured I'd move on to repairing the eyebrow portion of my 67 LH fender. Fabricating a repair patch might be beyond the capability of me and my tools at hand. Anyone got a bad 67-68 Chevy or 67-72 GMC driver fender they don't mind selling a piece off of?
Rob
Old 04-03-2019, 11:28 PM   #22
parb
I enjoy your thread. You're going all in - fun!!!
parb is offline   Reply With Quote
Old 04-06-2019, 04:58 PM   #23
Another 72
Red face Re: Another 72 Build Thread
Thanks! I'm not enjoying shaving my antenna hole. At least my burn-through patches are getting smaller and smaller.
Rob
Old 05-06-2019, 08:11 PM   #24
Another 72
Cowl panel is ready for filler. After shaving the antenna hole I decided to avoid butt welds on the thin stuff and used lap welds. If I'm unhappy with it over time, I can grind it all off and use butt welds. As it is, I'm thinking it will be pretty smooth after an acceptable amount of filler from POR-15.
Rob
Old 05-06-2019, 08:16 PM   #25
Another 72
For the driver fender eyebrow repair I ended up sourcing a solid eyebrow from a 69-72 fender. I know they're different, but the curve of the eyebrow from the 69-72 fender (see below) is a perfect match for the 67. A little hammering and a little POR-15 epoxy putty should get it ready for primer (see below).
Rob
