Steering Column Firewall Plate?
I recently bought a '63 C10 that has an aftermarket tilt steering wheel. The problem is its missing the plate that attaches to the firewall. Any suggestions where to find one? I've been looking everywhere.
(I also know I have to relocate the emergency brake cable, I just haven't yet.) Thanks! ![]() Last edited by mteribery; 08-30-2017 at 12:44 PM. |
Never Ending Projects
Re: Steering Column Firewall Plate?
I thought that was a rubber gasket that fit there, no plate.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
It's Better With Nitro
I found a decent one several years back when a friend bought a cab for the dash. It wouldn't be too difficult to fabricate one. Here is mine for reference purposes.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
Moderator
![]() ![]() Join Date: Aug 2011
Or you could call and ask any of these guys:
http://www.aspenautoaz.com/60-66-chevy-truck-parts.html http://www.4-5-6chevytrucks.com/used-parts.html http://ctcautoranch.com/index.html Or you could ask a member here named - vetnat
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 08-30-2017 at 02:43 PM. |
#5 | |
Is the plate that vin63 posted the right plate for that style hole?
I'm not aware of another style plate for the 63-66. I believe the 60-62 were curved and oblong in shape.
#8 | |
Also, where did you find the catalogue at? I'd love to order one! Last edited by mteribery; 08-31-2017 at 08:29 AM. |
Custom Truck Lover!
[QUOTE=mteribery;8028913]That helps a ton! Looks like I need to purchase the seal as well, I just ordered the plate from Aspen Auto. Thanks!
Also, where did you find the catalogue at? I'd love to order one![/QUOTE Nick at Aspen is the man. The other part is a rubber seal.
Squarebody guy |
#10 | |
[quote=YOLO;8029754]
Thanks!
1963 Lifted C10 4x4 Long Bed Fleetside http://67-72chevytrucks.com/vboard/s...37#post8028937 |
Which catalogue is this and where could I find one? Thanks!
There is a similar diagram in my 1963 Chevy truck shop manual.
#13 | |
Posted via Mobile Device |
Ah, that pic makes more sense. Yep, should be fairly easy to fab.
