rolling cab on its back side
Ive got my truck completely apart now. Cab is on rollers in garage.
I plan on laying it on its back (back window side). So I can work on the bottom of it. Do you guys see any issue with this. I think it should be structurally fine. But thought i should ask the experts on here. Mike |
It's Better With Nitro
Re: rolling cab on its side
I did that to weld up the dozens of holes previous owners had drilled through the floor for various things, including different seats. I also took the opportunity to seal, paint, and then finish the underside with some heat resistant acoustic coating.
I did set it on wood planks with a couple of 4x4s notched for the drip rail. I had a couple of friends help me with tilting, lifting, and setting the cab down.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
Moderator
![]() ![]() Join Date: Aug 2011
Re: rolling cab on its back side
Piece of cake, I used 4'X8' plywood on the garage floor.
I placed a piece of heavy carpet onto a pallet and set the cab onto it with the help of a few friends. It worked out very well. If you're painting the interior, it's a good time to strip the roof as well. Sanding above your head isn't much fun.
Awesome. Thanks for the help and suggestions. I guess its a done deal then. I'l flip it over.
