Old 10-27-2003, 04:54 PM   #1
PureChevy
PureChevy's Avatar
antenna rust??
I have got an issue with my antenna. It seems like the rubber gasket has rotted away and the antenna just flops everwhere. How can i fix this? Can i buy a gasket for the antenna?? I dont have money to do any kind of body work etc. here is a picture.
thanks
1972 k10 4x4 LWB (Sold in 2005)
PureChevy is offline   Reply With Quote
Old 10-27-2003, 05:44 PM   #2
busterwivell
Until I saw your picture, I thought I could help you. I don't think you have as much of a gasket problem and a problem with a place to mount the gasket.
Bill - Tucson, AZ
47 Chevrolet 2 dr sedan
56 Chevrolet 210 2 dr sedan
66 Chevrolet Malibu 2 dr 4 speed
71 Chevrolet C30 Longhorn
86 Chevrolet Monte Carlo SS (Sold)
01 Chevrolet Tahoe
IM - BUSTERWIVE@aol.com
busterwivell is offline   Reply With Quote
Old 10-27-2003, 05:50 PM   #3
PureChevy
PureChevy's Avatar
What can i do?? Any ideas??
Old 10-27-2003, 06:13 PM   #4
palallin
There are probably thousands of cowls in that color lying around the country. I may even know of one for sale. Locate one and install it. It's really simple as body projects go, probably really cheap, and it will prevent you from going nuts trying to repair a hole.
YMMV.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt.
palallin is offline   Reply With Quote
Old 10-27-2003, 06:16 PM   #5
jamis
F.A.S.T. president
jamis's Avatar
How about some stainless washers till you can do the body work.
Or an aftermarket antenna with a bigger base.
jamis is offline   Reply With Quote
Old 10-28-2003, 08:35 AM   #6
PureChevy
PureChevy's Avatar
hey Palallin, what do you mean a cowl??
anybody used aftermarket antennas? Anybody get pictures??
Old 10-28-2003, 09:02 AM   #7
JimKshortstep4x4
Talking
It looks like the hole is still intact and the antenna base may be large enough to cover the hole. If you can get a hole measurement, I can check the bases that I have to see if they will cover the hole. Another option is to use a Ford antenna, (if you don't want to change the cowl which the antenna mounts to)
since the older ones have a fairly large base that screws down with four screws.
Regardless you will have to pull the cowl to remove the antenna, and that is pretty easy to do. There are two bolts on each side and two rows of phillips screws to remove after removing the wiper arms.
Good luck!
Jim
Old 10-28-2003, 09:14 AM   #8
Blue Beard
Blue Beard's Avatar
Replaceing the cowl would be easy and cheap compared to how long it would take to do body work and paint......
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 10-28-2003, 09:26 AM   #9
VTKidder
This is a cowl. Here is a link to one on the parts board for $25. (link They're quick and easy to replace. Best of luck.
-adam
VTKidder is offline   Reply With Quote
Old 10-28-2003, 12:30 PM   #10
PureChevy
PureChevy's Avatar
thanks everybody for the help.
