Old 09-12-2017, 05:52 PM   #1
1969 Project
1969 Project's Avatar
Turn Signal switch housing
Stupid question but I have been fighting with this turn signal switch housing for a while now and I can't seem to get it back on. Anyone have any tips?
1969 Project is offline   Reply With Quote
Old 09-12-2017, 07:12 PM   #2
djeCST
djeCST's Avatar
Re: Turn Signal switch housing
They can be a little fussy sometimes. Here's a thread I did a while back when I was working on my column:
http://67-72chevytrucks.com/vboard/s...d.php?t=711090
Be patient, you'll get it.
Dennis
'70 CST/10
'55 Bel Air wagon
djeCST is offline   Reply With Quote
Old 09-13-2017, 12:15 AM   #3
1969 Project
I Finally got it. Thank you sir.
Old 09-13-2017, 10:59 AM   #4
djeCST
djeCST's Avatar
Outstanding. Glad you got it going.
Dennis
'70 CST/10
'55 Bel Air wagon
Old 09-13-2017, 05:19 PM   #5
1969 Project
So I guess I lied. The housing will not go down all the way as you can see in the picture. Also I can turn the housing by hand with everything installed and the shift indicator is way off. Any idea on what I can or should do to get this correct. I have been at this for two days now and its pretty frustrating as this should be a pretty straight forward job. Any help is appreciated.
Old 09-14-2017, 04:08 PM   #6
1969 Project
Looks like the rubber spacer is causing it to sit uneven for some reason.
Old 09-14-2017, 05:04 PM   #7
randy500
In your first picture you can see the rubber cone shaped washer, it's sitting out too far, it rests on a white plastic washer that has an outside key way, I bet the plastic washer is not located in the outer column slot.
Which I assume prevented engagement of all 3 tangs on the turn signal switch cover to the outer column.
randy500 is offline   Reply With Quote
Old 09-19-2017, 04:11 PM   #8
1969 Project
Does anyone know where I can get one of these rubber spacers?
