Old 09-14-2017, 09:54 PM   #1
the ideaman
the ideaman's Avatar
Adapters for c5 fuel regulator
What are part numbers for c5 regulator to AN6 line? Using Ptfe hose and a 3/8th" hard line down the frame rail. Finally getting to work on my '67.
the ideaman is offline   Reply With Quote
Old 09-14-2017, 10:30 PM   #2
mongocanfly
mongocanfly's Avatar
Re: Adapters for c5 fuel regulator
c5 regulator? ...is this the commonly used vett filter/reg with pushlok fittings.?
Old 09-14-2017, 10:48 PM   #3
the ideaman
Yes, the corvette filter/regulator. I bought kit from summit,but it's incomplete. The line to the filter from the pump has a barb, but I'm unsure of the fitting for it.
Old 09-14-2017, 11:33 PM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
It should be GM Quick connect no? 3/8 feed, 5/16 on the return from the reg to the tank.
If your going to AN, then its a 3/8 Quick Connect->-6 male AN. The other one is 5/16 Quick connect->-6 male AN. The female side of the regulator accepts the 45* flare hard lines for fuel.
Summit and Jegs both carry the common Russel or Earls versions of what your looking for.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 09-14-2017, 11:38 PM   #5
mongocanfly
^^^^yep....brew beat me to it...^^^^...be sure you plumb it up correctly. .
